plug wires..
Results 1 to 14 of 31
plug wires..
    Senior Member milkmoney's Avatar
    vegas
    Default plug wires..
    i want to get longer plug wires for the jet, i want to route them around the valve covers and not have them go over the top like they do now, how do i know how long to get and which ones for sure? the boat is not with me..and where is the best place to go get them at..or online?? its a 460 ford with a msd dizzy and box with a chip in it..thanks..
    Senior Member tx-19's Avatar
    wittmann,az
    taylors are pretty good for the money.but you are going to have to make them your self.
    vegas
    Quote Originally Posted by tx-19 View Post
    where do i get those and it cant be that hard to make.. do i have to get msd ones to plug into the dizy etc..
    Senior Member VAMI's Avatar
    srq,florida
    Yes Taylors are very good,get the universal ones and you cut them to fit.Jegs or summit sells them.
    wittmann,az
    Quote Originally Posted by milkmoney View Post
    no
    wittmann,az
    make sure you use the ends for the hei cap
    vegas
    8mm ok to get. and does it have to be heat resitant??
    Member TrynPas's Avatar
    Litchfield Park, AZ
    MM- Taylors are great. I used the 45* boots (universal set) and don't forget to check out the little wire looms/holders from taylor too (mine were red). They sell them so you can stack them either vertically or horizontally (I bought the vertical ones). If you buy the universal wires don't forget to buy a good crimper (for ignition wires), it makes it alot easier.
ID:	33610   Click image for larger version.
    You done got my kentucky ass all confused!!!
    Senior Member Boost's Avatar
    Pomona ca
    Default Plug wires
    Go with the MSD wires scence you have the dizzy and box, Eddie Marine (909) 945-2830 has the MSD wires 8mm for about 75 bucks.
ID:	33614   Click image for larger version.
    vegas
    ok thanks guys for all the good info. i have to find a special mounting bracket/holder due to the type of valve covers i have. just not alot of space where the bolt goes into the head..
    Yucaipa, California
    whatcha doin with the old wires? i'll take them!! Your motor/boat looks great by the way.
    1992 Eliminator Daytona 21'
    vegas
    Quote Originally Posted by Tahiti Boss21 View Post
    thanks for that..,, i have valve covers also for a ford, i need to post pics and put up for sale.. will let you know when i get the new ones, should be within the next couple of days..
    Lexington, KY
    Thumbs up
    Boat is looking good Milkmoney!!!! Plug wires are easy, just get the universal ones, and run em' how you want.
    Good luck.
    HJ
    Senior Member nick's Avatar
    Fullerton & Water Wheel Resort
    What kind of valve covers do you have for sale? Nice boat btw...
