berkley bowl shaft seal
Results 1 to 5 of 5
    Jul 2015
    Default berkley bowl shaft seal
    Anyone have a seal # want to try to get one local.Thanks John Sr
    It might help to tell where you are from to know where local is.
    parker seal 9625 h1l5
    Jul 2015
    Default seal
    Maryland.Is that parker seal the rubber encapsulated steel shell type.Thanks John Sr
    FYI Just about any seal you might buy locally that "specs out" to appropriate sizes will not likley hold up , you need to look for Clipper type seals $14.00 bucks in stock ,call if you need to order
    Manville Rubber Products, Inc
    Parker - CLIPPER OIL SEAL
