dog house
Results 1 to 3 of 3
dog house
    Sep 2015
    Default dog house
    im building a dog house engine cover for my boat.going to build outa ply wood.and fiberglass it resin.does it get hot enough in there to melt the resin.have water jacket headers.going to put a fiberglass hood scoop on to let it breath.and prob vent it down low also.anyone have any exp with this or pics......
    Senior Member Sanger-Spectra's Avatar
    May 2010
    Default dog house
    If you melt the resin you got big problems... vent it well make sure you have good clearance and seal the plywood. I like to use cloth to seal the plywood, encapsulate the wood and use matt for your structure.
    Here are some floors I am doing right now, there are 100's of ways to do this, I have just seen floors done like this last for decades. Resin alone will crack that why I like to use the cloth. I am assuming you are using a polyester resin as well, I have never used epoxy resins but have seen some good stuff done with epoxy, it is new tec vs old school with the polyester.
Name:	Top b4 cloth.jpg
ID:	798233   Click image for larger version.
Name:	top cloth drapped.jpg
ID:	798241   Click image for larger version.
Name:	bottom matt cloth2.jpg
    Heres mine... wood, carpet, vinyl, diamond, fiber... the only issue I had was the sun reflecting off my breather an burning a line like a magnifying glass into the carpet. Covered the top of breather with a piece of vinyl material...fixed.
    Made In The Shade
    Custom Window Tinting
