trim tab/transom extension tanks
Results 1 to 1 of 1
    Jan 2014
    Default trim tab/transom extension tanks
    I want to add trim tanks that act as transom extensions and extra flotation /trim tab (each side of jet outlet, about 3ft wide X 2.6fthigh and apron 2 ft long, bolted to aluminium boat transom . I may use was gas tanks . is this weight that far aft a problem? I think i will need to ballast aft end down due to mid engine and trans on my amphibian project
ID:	799497   Click image for larger version.
ID:	799505   Click image for larger version.
ID:	799513   Click image for larger version.
ID:	799521   Click image for larger version.
ID:	799537   Click image for larger version.
