looked in my pump and found this?
Results 1 to 14 of 19
    i got skiillllzzzz.... fast76rogers's Avatar
    clearlake ca
    Default looked in my pump and found this?
    ok i got pissed and decided to keep the rogers and make it go faster. today i pulled everything out to do a pump set back.i took bowl off and found this thin piece of stainless cut and rivited inside to the bowl.see the pics i attached. is this a home made bowl stuffer? should i leave it in or take it out.never had any problems with it but it sure looks like it could cause problems if it came loose.any helpful info would be great.
ID:	33766   Click image for larger version.
    i'd be more concerned about those veins lookin a bit too cut on to me, better check the clearence between the bowl veins and impellor veins, i'd bet it's wayyy out. you can cut some off the mounting flange on the bowl to bring it forward. is that a split bowl?
    clearlake ca
    it is a two piece bowl.the impeler was rubbing on the plate alittle.the vains are flush with the plate,dont think its that far off.
    Well the "concept" was OK and the "thought" was there just not the way I would have gone about it , call if you need help (i'd be a little concerned about the attachment as well Tom
    jbp stuffers
    clearlake ca
    should i dump this bowl and get another one?if so what are my choices to mate up with my berkley suction housing?for a decent price.
    Quote Originally Posted by fast76rogers View Post
    Personally I'd drill the rivets out and "clean up/finese" the bowl and redo the Stuffer plate in an aluminum piece (drill ,tap and reattach) it will prooly work fine for you Tom
    One part at a time... JohnnyNitrous's Avatar
    Surrey, BC, Canada
    Hey Tom, is there any milling needed to install one of your stuffers? How do you check/set the clearance to the impeller?
    B1 Racing cs19's Avatar
    How long has it been in there? If you havent had issues why take it out? How close is it to the back of the impeller? The real problem is you cant take it out to change the dimensions later down the road when you do pump work. You might get lucky any not need to tweak the impeller/stuffer clearance though. Good Luck.
    B1Racing.net
    Looks like the plate is on the thin side, see the scuff marks between the rivets, most of the plate one I've seen are 1/8th in plate.
    Tom your stuffer is killer
    clearlake ca
    the plate is thick,rivits are loose.thats why it was rubbing
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    wonder who designed it
    Sounds scarry to me!! Next in the food chain?? THE BOWL !!!!
    In addition! JBP's deal looks really good! Nice job! JPB.
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Beats finding rocks plugging everything up.
    Wags
