Blower Primer System
Results 1 to 11 of 11
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default Blower Primer System
    February 21, 2009
    Several different people have this type of basic system and it works fine when you find the correct jet size to use.
    So Cal
    We never used a jet, just an open nozzel ... and the solenoid/hose has to be above the port it's going into because of the gravity feed.
    It looks like you're loosing the bottom 1/3 of the available fuel in the way you have it set up there ... you should tap that solenoid into the bottom of the bottle and raise it a little ... the bottom of the bottle looks like it's even with the port it's feeding.
    It's so easy to use it's stupid ... that's why Tom Papp called it the "Stupid Bottle"
    Is this new for you this season Willis? If so, you'll love it.
    Senior Member cheyenne580's Avatar
    Hey Willis...My system use's a small electric pump and a n20 fuel solenoid.It work's pretty good and it eliminates the bottle.It's feed from the bottom of my {T} tank.Hope this help's you.I can send pics to you if you give me your e-mail address.
    Jim S
    So Cal
    Quote Originally Posted by cheyenne580 View Post
    Jim S
    I'm 99% positive that is Wilis' blower & hat ... I've used the pump/solenoid/one way check valve before ... I prefer the stupid bottle myself for a racing application.
    Gardena, CA
    There were some people who are stepping up and they needed to know how others hooked theres up
    Thanks guys
    Willis
    It's a sickness Eliminator#1's Avatar
    QC, Mcintyre
    willis gonna be @ elsinore?, maybe ill be there, thx for the parts
    LIFE'S GOOOOOOOOD!!!!!!!!!!
    QE 072
    Quote Originally Posted by BUSBY View Post
    I'm 99% positive that is Willis' blower & hat ... I've used the pump/solenoid/one way check valve before ... I prefer the stupid bottle myself for a racing application.
    well i guess it's what works for you may not work me.Opinion's everyone's got one.
    So Cal
    Here's how we installed it on Ron's boat ... he had a fuel pump and braided line that he wouldn't get rid of ... that's the hose you see hooked up to it. He just loves extra weight in his boat
    You'll also see a vent installed into the cap to assist in draining
    PASO ROBLES CA cougar63's Avatar
    PASO ROBLES
    we used the small electric fuel pump and solenoid dealio from the bottom of the t-tank very simple worked great
Name:	Misc. Pictures 052.jpg
    Senior Member BAE 557's Avatar
    Primer tank with O-ring sealed cap (must be able to pressurize with portable air tank), N2O solenoid, fuel line, nozzle body and jet.
    No need for a fuel pump.
    Blue Thunder, Mach 1 Project *** Completed ***
    Pax Per Potens
    Semper Fidelis
    No Way As Way
    No Limitation As Limitation
    PASO ROBLES
    Like Jim Said,to Each His Own,the Fuel Pump Deal Is Just Clean And Simple
