SS Impeller problems - HELP
Results 1 to 14 of 31
    Future GN Racer! fdlock890's Avatar
    Las Vegas
    Default SS Impeller problems - HELP
    I have a Berkeley Stainless Steel impeller, and I was having it cut from an A to an AB, and a crack was discovered. See the pics. Well the issue is the back side has a huge casting flaw. Has anyone ever encountered this? If so, what did you do, and who did it? Any and all help is appreciated...
ID:	34110   Click image for larger version.
ID:	34111   Click image for larger version.
ID:	34112   Click image for larger version.
    Morgan Hill
    Quote Originally Posted by fdlock890 View Post
    IMHO I would start over and scrap this deal, not worth the risk...
    GT
    GT
    Las Vegas
    GT
    I was thinking that might be what is going to have to happen, but it is alot of coin. (as you know). I am running a 21' AfterShock and 700 hp.
    Morgan Hill
    Right now I have a worked GTH "A" stainless, the difference from the GTH to the Bekeley is friggen spooky, good luck.
    GT
    GT
    Senior Member RhinoWood's Avatar
    Sacramento, California, United States
    GT
    Lock.....I don't know that much about jets except they spin very fast, never the less....I'm afraid if we were to weld this it would crack behind the weld......I mean I'm kinda with GT, I'd be real leary of spinning this deal this fast like you guys do. Is it something you recently purchased? Or is it something else. I'll try anything but I'd hate to see you destroy your pump. Bring it this weekend if possible so we can look at it in the light. Flaws usually mean there is an impurity in the metal, It will be exagerated <sp> by welding......
    Hopefully I'm wrong, I know these impellers are'nt cheap. Like I said, bring it and we'll figure it out.
    Wood
    "Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, Beer in one hand, body thoroughly used up, totally worn out and screaming, "YEE HAW, what a ride!"
    Senior Member Futs's Avatar
    Orange CA, Big River
    Send it to MPD and let Jack work his magic. It is fixable. Mine was cracked in 5 spots and he did it up and its better than new.
    GT
    Whats the differance? Its a direct copy of the Berkley isnt it. I run the same impellor (GTH). I have no issues with mine... Its lightened, detailed and balanced...It leaves Hard!
    Morgan Hill
    The casting on my GTH is twice as nice as my Berkeley, the GTH has been balanced and polished so its very easy to see how clean the cast was, the metal just looks cleaner IMO, the GTH is a nice piece and I was only using it as a reference.
    GT
    GT
    Why are they cutting on the front side, to make it an A/B?
    Like Futs said, the guy knows what can, and cannot be done, with impellers.
    I think Berkeley should eat this one. should not have passed inspection.IMO
    #55
    Las Vegas
    I agree with you. The problem is, I bought it from a friend, and not directly from Berkeley.
    prob to repair the gash that rock made , would account for the cracks. a local buddy has a impellor with the frt cut on it and its shit outta the hole, i can swim faster.
    Concord, CA
    Default ss impellor
    Per Jack at MPD, most all castings have some flaws. Any new part he gets has to be welded up before and during the finishing stages. He has welded them up for me, and no problems.
    Jerry
    Just my OP , I'm sure it could be sucessfully welded, machined and made "useable" I personally wouldn't condone use of it however (possibly low HP application) the front side crack is clearly a direct result of the manufacturing flaw on the backside of that blade , again just my 02 Tom
