GM flywheel tooth count.
Results 1 to 14 of 14
    Member oldseddie's Avatar
    Aug 2014
    Default GM flywheel tooth count.
    I am freshening up a SBC 400 for my fishing boat and have to replace the crankshaft due to rusty coupler splines from the out drive that used to live behind it. I recently replaced the starter with a top mount on my three point mount/bell housing. Since I have to have the crankshaft balanced I thought a change from a flywheel to a lighter flexplate would be in order. I don't intend to pull the engine until winter sets in. Does anyone know how many teeth are on the flexplate used with the top mount starter?
    Sent from my SM-P900 using Tapatalk
    Coupler spines have nothing to do with the crank. The coupler bolts to the flyweel
    Aug 2014
    No but on an outdrive it causes the input shaft to push on the crankshaft when trimming and that will take out the thrust surface. I have determined that indmar used a 168 tooth 14" flexplate with the three point mount bellhousing.
    Sent from my SM-N900V using Tapatalk
    You are correct on the 168 tooth count. May want to check transom flex-engine alignment before reinstallation as input shaft should never make contact with crankshaft
    Aug 2014
    How does one check engine alignment? I gave away my mercruiser alignment tool when I got back to a jet.
    That tool you gave away is the only way I know
    Jul 2014
    Chevy also used a smaller 153 tooth flywheel on some SBC....
    Aug 2014
    I retained the right to borrow it back if I need it. What is the program on using it. Do you temporarily mount the suction housing without the impellor shaft and adjust mounts till the tool rotates smoothly like a mercruiser out drive?
    Senior Member andyc's Avatar
    Feb 2010
    Valley of the Winds
    Default Starter
    Make sure the new starter your mounting on top is counter rotation too. 168 tooth internal balance I believe for the flywheel (no counter weight).
    Aug 2014
    Already running the top mount starter. Don't want to go back to bottom mount. 400 sbc is external balance.
    Quote Originally Posted by andyc View Post
    If it's a stock 400 crank it is externally balanced, and different than a 454 counter weight if I am not wrong.
    Didnt realize you were putting the mercruiser motor in a jet. Pretty hard to align with 3 point mount. Up and down with an inclinometer. Side to side looking at 3 point flange alignment to jet housing or measureing off bellhousing bolts to sometbing on jet. Originally there was a tool that slid over the jet shaft and then it had a drill jig made into it to set tha front mounts. Havent seen one in over 40 years. Using that 3 point mount. Better make sure you have the right driveline length. Too short. You will bend the pump shaft. Too long. So long thrust bearing
    Default 400/454
    Right, nothing about a SBC 400 and a BBC 454 are remotely the same.... While both are externally balanced, the external weights are totally different.... And not interchangeable...
    Ray
    LOUD BOATS SAVE LIVES
    Aug 2014
    I should mention it has a 350sbc in her now but one of the vortex heads is cracked. I can't see throwing money at it when I have this 400 built by a NASCAR engine building buddy. We used the 153 tooth flywheel with the alpha out drive but it had a bottom starter. This engine pushed my heavy welcraft 60mph. Should push my new boat even faster since it weighs a ton less.
