Drive Line...
Results 1 to 14 of 35
Drive Line...
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default Drive Line...
    I have the old school drive line that bolts right up to the flexplate/crank. Not PTO flange needed. What kinda power will these things hold up to?
    San Clemente, Ca
    Whoops, forgot my pic
    Shell Knob, MO
    They will handle a lot of power. Not afraid to put 1000 hp to them.
    San Clemente, Ca
    Nice, one less thing i have to buy. Curious, my pump was set back about 5.5" the jetaway will make up about 4.25 of that right? Can i use a spacer/shim to fill the rest of do i need to get a new drive line or if possible have this one extended? I know i could move the motor back but i'm already getting close to the transom.
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    i had to move my motor forward for a better ride about 12" from the transome is were my motor is in the cole i had a drive line made at a jeep shop but could be done at home if you had the tools and knowledge
    TEN THIRTY ONE RCB19's Avatar
    Lot's of people use a machined aluminum spacer between a 2 piece U joint but since yours is a one piece deal one would have to be made to go between the flex plate and drive line. I personally have not seen it done this way and I'm not the right guy to ask. I would not move the motor back with what your doing.
    RCB
    Golden Shores,AZ
    did you have to go forward to ross
    If I remember correct the rear motor plate is 23 3/4 from the transom. Yes we moved it forward. The TR's responded well with that placement at speeds we are trying to run.
    RCB
    Quote Originally Posted by RCB19 View Post
    Does someone make an aluminum spacer? How large can they go? And are they strong? Just curious....
    Quote Originally Posted by Pw_Tony View Post
    MPD can machine those spacers for you. There are racers using them into the 1000+ hp range.
    RCB
    Bullhead City, AZ
    I am moving the 429 forward about a inch and a half for now. How far can we go with a spacer ? We are at 23.75" right now !
    BTW - Thanks Ross
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Quote Originally Posted by Squirtin Thunder View Post
    BTW - Thanks Ross
    Go to bed dammit.... I got to wake up at 7am tomorrow and go to Bagdad... and I never even signed up for the Army
    Bullhead City, AZ
    I thought I was having flash backs the day we drove into Bagdad !
    Jim & Amanda Rich
    CJ 72 & 53c
    San Clemente, Ca
    When talking to jack he seamed to think i may need to move the motor back and not forward. This was when we were talking about the boat wanted to possibly fall on it's nose and porpoise after my mods.
    A spacer between the flexplate and drive line just seams like a bad idea, but i guess thats pretty much what a PTO is doing...
