Impeller selection for N/A 632"
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 51
    Sep 2014
    Rockford Il
    Default Impeller selection for N/A 632"
    A friend of mine is making me a great deal on a blueprint 632" motor. 815/800. How do you select an impeller? I do know I have an 'A' aluminum in there now and it turns 54-5500 on my tach (not sure how accurate it is) @62-65 mph. Hardin 454. As far as I know the jet is stock. Im sure Ill need a steel one. Eliminator sport 20.5
    May 2014
    It would greatly help if you knew at what rpm it made its hp and tq
    Sep 2014
    Rockford Il
    Senior Member Double A's Avatar
    Apr 2010
    Yakima, Washington
    AA looks pretty nice for your engine.
    Those A/F numbers look lean on that chart up high rpm.
    Mar 2010
    Clarksville, TN
    Really depends on what you wont to do with your boat .. Cruising and pulling tubes/skiers I'd go with the AA, but if your lookin for performance then I'd keep the A and trim as needed .. You really wonna go to a bronze or SS impeller though, the aluminum is junk at that power level .. Might need to upgrade your shaft also
    Sep 2014
    Rockford Il
    Tny, I like to cruise at 3 to 3500 rpm, there could be skiing or tubing but it would be less than 5% of the time. When you say you'd stick with the a and trim it are you referring to trimming the impeller. If not what other trim are you referring to
    May 2014
    Yes he is talking about trimming the impeller down ..
    The best setup in that boat would be an A or even an AB ss impeller with an inducer behind it but that starting to get expensive don't know what your looking to spend or how hard your goin to lean into that motor but your goin to need to upgrade the main shaft start messing with loaders and I hope your pump already has a shoe and ride plate you will be needing that too
    if any of this info seems overwhelming your best and cheapest bet in the long run is to call Chris at b1 racing tell him what you have and what the end goal is he will work with you and not try and up sell you and crap you don't need
    Jan 2013
    First of all with that much hp don't go aluminum, figure out which brand then get a chart to pick size
    Jan 2013
    This is the chart for an A. High helix ss impeller chart from American turbine
    Jan 2013
    Sorry my sheet is hard to read, call up American turbine and they will send you a chart for any impeller, after seeing your dyno sheet I would look at an AA chart, and you can bet the chart will be on the money if your pump is fresh!!!!! There are several great pump building guys on this site, I personally like the High Helix impellers, but that's just me
    Sep 2014
    Rockford Il
    what else is affected by high torque?
    Jan 2013
    A pump builder could tell you better , but basically the shaft and cv joints is all but with that kind of power I like a jetaway depending on your use of it and for safety I would really inspect your loader!!
    Jan 2013
    But I want you to know I am only familiar with a dominator pump and I had mine done by Hi-tech performance here in Missouri where I'm at, but you have Chris at b-1 out west , there are many good pump places to call, depending on your location
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by horsepowerjunkie View Post
    Ya, trim the impeller .. Not a big fan on it but you could use the aluminum impeller to get a feel of just how many RPMS your engine will turn and fine tune it and then get yourself a nice SS impeller, just dont beat the hell out of it .. I bet with your HP and TQ a nice detailed A or A/B will be perfect for your combo . Do it right the 1st time and you wont have to worry about it again, it will cost alittle more but if you get a 17-4 shaft and a inducer and nice SS or bronze impeller you can throw just about as much HP at it as you wont.. Good Luck
    What pump and bowl is in it ??
