Who's running dominators
Results 1 to 6 of 6
    Sep 2014
    Rockford Il
    Default Who's running dominators
    I have a choice between a 2 circuit and a 3 circuit Dominator. I've had plenty experience with two circuit Weber carburetors and I know how that can be I don't know what to choose
    Jan 2013
    Your going to get alot of answers her but my opinion is you can't beat the three circuit , allows to tune in any range!!!
    Jan 2013
    And yes I am running two 1120 by Gary Williams on a pump gas 565 with a straub cam, its a lake boat it only turns 6200, they are 3 circuit, I run a o2 sensor and my fuel curve is perfect!!!! I idle alot in no wake zones, it out idles my single carb setup!!
    I am running an 8082 on my 572...off memory thats a 2 circuit.
    I think I was told it would be easier to tune than the 3 circuit deal.
    Other than a pv(s) change....and a little idle adj she was good to go.
    I would be curious as to what the advantage(is there is one) of the third circuit is.
    Sep 2014
    Rockford Il
    The guy is offering either 2 or 3 circuit. One or the other. I just don't know how important it is with a boat
    Oct 2011
    Sandia,Tx. 78383
    2 Ten Fiddy'son mine ,
    Get the 3 circuit if he's giving you a choice !
    http://oathkeepers.org
