Double Drilled snoot and bowl HP level
Results 1 to 14 of 19
    Default Double Drilled snoot and bowl HP level
    I know this is a loaded question and will get a million different answers (kinda like aluminum impeller hp level).
    At what hp level does it become necessary or a good idea to double drill the bowl to the intake housing and the snoot to the bowl?
    this is on an early dominator 12-S
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    I will star off the bidding at 750hp. Once I went above that I had leakage problems
    Quote Originally Posted by Master Sergeant View Post
    X2 except when i hit this HP level i broke the droop off the bowl, scared the living snot out of me
    Mar 2010
    Clarksville, TN
    I'm around 900 in my lake boat and nothing is double drilled and no issues blowing gaskets .. In the race boat, the bowl is double drilled but the droop is not .. Still no issues !!!!! I'd go with a 1000+
    Ok...I plan on going to about 750 max with my mild turbo build up.....sounds like I should be on the edge of "safe"
    Quote Originally Posted by SS496 View Post
    Its real cheap to do so why not? I have my bowl, droop and the front part of the pump where the u-joints connect to the pump all double drilled.
    May 2014
    Do you have the bowl and suction housing out of the boat ?? Or are you just worried about having to mess with it?
    I will have the bowl out for a impeller swap soon......does seem like a good time to do it.
    Oct 2011
    Sandia,Tx. 78383
    I had mine done while pump was out , seemed like a No Brainer ...plus I've seen the plastic wedges get blown out even in some boats with moderate power ...will it actually help in my setup ? Who knows but I sleep better
    http://oathkeepers.org
    Default lost bowl
    I blew the bowl off onetime. Pretty dangerous as it was swinging around by the cables at high speed. Could have been because I was running hard across some rollers and stayed on the nos.
    Senior Member Jetdream'n's Avatar
    Sep 2009
    Concord, NC
    X3 when my droop blew off, it threw me into dash and I was close to going swimming. I would at least do the nozzle side of the bowl.
    Apr 2010
    Rocklin, Calif.
    Man..if it's apart just do it! No matter I always have mine done
    Denton, TX
    For the guys who double drilled and studied or even those with regular bolts, why not have them safety wired also? Seems to be full proof at that point.
    Mar 2010
    Clarksville, TN
    Most of the time if your blowing gaskets and bowls and droops off, you either don't check your shit, bolts are to short, or some major loading issues
    Fuck it, drill it
