Hydraulic Diverter Q?
Results 1 to 9 of 9
    Senior Member W.O.T's Avatar
    Campo Ca
    Default Hydraulic Diverter Q?
    Does anyone have a pic of how and where their hydraulic diverter pump is mounted? Just bought one and it doesnt really have mounting hardware I wish to use. Thanks
    Senior Member activeshack's Avatar
    Virginia
    Quote Originally Posted by W.O.T View Post
    Mine is under the jump seat in the back. There's a pic. on the thread I attached. I also got one of the billet brackets shown on there and replaced the cheap POS that comes with the pump since that pic. was taken. The guy sells the brackets on E-bay.
    http://www.performanceboats.com//sho...light=diverter
    Senior Member cave's Avatar
    Mesa, AZ
    I have one of these.
    Check post #7. on this link
    click here
    Takin it home
    Charlotte, NC.
    click here
    Mine was simply bolted to the transom before i got it. I have not touched it and it seems to be holding just fine. If i ever remove it ill be gettting something either exactly like or very similar to this.
    El Cajon, CA.
    click here
    I used one of these as well. I modified mine a bit though.
Name:	divertor bracket 4.jpg
    Senior Member cbcp's Avatar
    Carlsbad
    click here
    Just bought one and they are top notch.
    Mesa, AZ
    W.O.T, hook up a relay if you don't have one already. This will save your pump and you might get bit faster response with the Hydraulic. Banderlog has a nice one. You can get away with a Bosch 5 tab. but you will need to carry spares. if they get soaking wet they fail.
    Nice ride.
    Takin it home
    Nice ride.
    X2 on the Banderlog relay, almost makes the trim too fast for lake use, but a racers dream for the quickness.
    Campo Ca
    Nice ride.
    Thanks guys that bracket looks good and i will look into that relay. Thans the first time ive heard of it.
