Start up oil
Results 1 to 10 of 10
Start up oil
    Jul 2015
    Default Start up oil
    What's a good oil to use on a fresh start up,540 Chevy does have assembly lube on all the surfaces now ect bearings.And will prime the oil pump.Thanks JOHN SR
    Senior Member spectralen's Avatar
    Aug 2009
    Mi.
    Is this a roller cam? Hydraulic flat lifters need the high zinc for break in. Valvoline Racing oil has zinc in it.
    Senior Member poncho's Avatar
    SE Mass/Bering Sea
    I switched to Joe Gibbs due to availability in my area, most local builders like it, just pricey.
    Senior Member dryhoze1's Avatar
    Sep 2009
    San Juan Capistrano / San Clemente, CA
    Poncho gave you a great recommendation.
    I also love & had very good results with Brad Penn and a bottle of Lucas. Pictured..
    iv seen it online from Summit Fwiw.
    good luck !!
    Sorry the the pic is sideways, computer shit I know nothing about.. Lol
    SE Mass/Bering Sea
    Quote Originally Posted by dryhoze1 View Post
    good luck !!
    I've used Brad Penn for a decade but no one carries it, I switched when I went to the dyno this spring and changed oil multiple times...3 different shops said they liked Joe Gibbs, especially the break in oil....just damned expensive.
    Brad Penn is easily available through Amazon for about the same price as Valvoline, and they produce a break in oil as well. I have never run additive in with the Brad Penn in any of the engines I have built, flat tappet or roller.
    Certainly there are other good oils, but I have pulled apart engines (including my own turbo race engine) that ran on the Brad Penn oil, and have been very pleased. You can spend more money if you want,, Torco, Lucas, etc, but not sure it gains you anything?
    Mohave Valley/Quartzsite
    good luck !!
    Lucas Actually makes a break in oil straight weight.. I've had no problems with it..
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    SE Mass/Bering Sea
    I started with Kendall in the 70's and switched to the Penn when that went down. I got caught short handed when I went to the dyno and allowed the switch because it was on the shelf, rather than wait, I didn't want to use it but he convinced me it was a good oil...he had 6 engines behind me.
    S.W. PA.
    Kendall was purchased by a refining group that is now Brad Penn. Same refinery, same PA grade paraffin base oil. If you can't find it Summit has stock all the time. I was talking to a drag racer who does my state inspection and he told me they were dyno'ing a 468. The break in oil was Brad, they went to lunch, dumped the Brad and went to Mobil 1 and lost 10hp on the next pull. When I went to the same shop to dyno an engine he told me the same story. Hundreds of variables or could be BS, your guess is as good as mine.
    We always run with the Lucas additive and depending circumstances and availability, Penn, Torco and as a default Valvoline VR1
