ALuminum driveshafts?
Results 1 to 13 of 13
    Senior Member badbug3's Avatar
    Default ALuminum driveshafts?
    Anyone running aluminum driveshafts in fast jetboats? Just wondering if they were much lighter if any than a lenco driveline.
    Senior Member bc18's Avatar
    Quote Originally Posted by badbug3 View Post
    Yep
    okie, lake Texoma
    Just run more BOOST
    H8-2-W8
    [email protected] first pass
    The member 1bdhondo's Avatar
    ca
    Just run more BOOST
    You don't need to if you have a turbo motor that makes 3000k hp on pump gas ( Chevy headed ) like that's possible lol you morons actually believe that ! Lmfao ! The dyno sheet says so !!!
    Just run more BOOST
    come on hass, you can give a better smart ass answer than that i know.
    okie, lake Texoma
    Ok, Keep your driveshaft & get a picklefork.
    H8-2-W8
    Ada, Michigan
    Quote Originally Posted by 1bdhondo View Post
    I agree those numbers sound pretty impressive but he has dyno results to prove it and Steve Morris is pretty well respected.
    I questioned about the standard "she makes 3500 hp" that all the Top alcohol guys claim.
    I've never seen dyno results of a roots blown alky motor making that hp number as of yet, and no one has produced any, but most seem to believe it.
    Is, "word of mouth" more believable to you than dyno results ?
    okie, lake Texoma
    That is a 5" bore spaced engine. Not really much left there that is common "chevy", especially the heads.
    H8-2-W8
    okie, lake Texoma
    Come on Mark! You dont buy that an alky engine with a roots can make 3500?
    H8-2-W8
    3500 hp impressive. Chevy heads?
    What does your place craft run to the 660 again?
    ca
    I understand that but just don't see it. What dyno are they even using to take 4000+ hp.
    okie, lake Texoma
    Steve busted the input shaft on that one. Custom made a handful of parts to get it to stand the tq.
    BangShift.com Watch A Twin ProCharged Big Block Bust the Dyno at Steve Morris Racing Engines! - BangShift.com
    H8-2-W8
    Quote Originally Posted by bc18 View Post
    I'd be surprised to find a conventional Chevy head that didn't crack after you hogged it out enough to flow enough to support 3,500 hp then tried to cram enough boost through the ports to make that kind of power.
    5.0 inch bore space stuff? sure. conventional stuff? probably not.
