Jet pump water pressure
Results 1 to 6 of 6
    I hate wakeboard boats
    Murrieta
    Default Jet pump water pressure
    Does anyone know what water pressure my jet pump puts to the engine. I have a 21 Daytona with b1 pump. I am instaling a oil cooler and worried about water pressure too it. Maybe someone else has installed an oil cooler on a jet boat and can help me. Thanks in advance fo the help.
    Senior Member namba860's Avatar
    Las Vegas, Nevada
    I have been running about 12 lbs in my latest boat.
    Prune-Picker
    Calif
    Quote Originally Posted by Magic1 View Post
    Why not ask b1 ??
    Cs
    San Diego, CA
    Enough to keep good flow to rid the motor of air pockets and no way for pressure to build up. I've been saying this for years. -08 inlet from the pump to the motor. -10 outlet from the stat housing overboard. Keep it simple.
    Been running my 21 daytona with oil cooler for years. I have a regulator on my 19 daytona for the simple reason it has some pretty serious pressure coming from the pump when throwing the spurs to it. 25 lbs or less. I've logged it with my data to set it and never look back. Running a regulator in sandy water conditions will prove to be a pain because it will clog with sand. The 19 only sees the track so not too much to worry about it
    Boat 405.
    Murrieta
    Thanks, the oil cooler is rated to handle 30psi so I should be good then. I appreciate the help very much
    Quote Originally Posted by Boat 405 View Post
    Brother-Magic1, follow what Widowmaker says, he knows his shit and has a really impressive 21..
