Hyd. palce diverter stop
Results 1 to 14 of 17
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Default Hyd. palce diverter stop
    i am going to change my 18 winger from manual place to Hyd. what kinda set-up are you guys running as far as a race stop vs full movement(lake playing for the rooster tails).looking for ideas.wanting something that can be easily adapted for when im @ the lake and wanna run the boat for a pass,thanks for any help Travis
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    May 2014
    Look at b1s website he has some pics and I know around the first of the year he is making a run of them so give him a call and put your name on one
    Senior Member Recycle Performance's Avatar
    Here's a simple design I made for a Bahner I was rigging,
    Hi Performance Rigging, Pre-owned and New Parts, Jet Drive Specialists, Powerdcoating, Wire Looms, Gauges, you name it, we can do it.
    Located in Anaheim CA. 714-630-3905. Contact: Bob Jeanblanc, email: [email protected], Website: www.marineiw.com.
    Senior Member Rivieraracing's Avatar
    Jul 2012
    Oregon
    Quote Originally Posted by Recycle Performance View Post
    Great idea!
    Mar 2010
    Clarksville, TN
    As that might be ok for a low HP river deal, seems alittle sketchy for a boat with some power. JMO
    There's a lot of stress on those parts
    I'm definitely never opposed to building things bigger, stronger, etc. So I'm not bucking any ideas or thoughts. That being said, this part has no relation to how much horsepower the boat has or how fast it is. The stop is not controlling or positioning the diverter. That is the cylinders job. The only thing this stop has to do is overcome the bypass on the hydraulic pump when the stop is met. In this case the pull strength on a 5/16-24 stainless nut is over 2000 PSI. If the boat is equipped with a Place pump, it will never see over 300 lbs of pull pressure and if it has one of my HP pumps it will never see above 550 lbs of pull pressure.
    May 2014
    Ya what bob said ....
    ??? Aint sure I follow that theory. Gonna require a timer to turn that pump off!!!
    Dec 2010
    Sapulpa ok
    We run the same deal. I also made a limiter on the top as well. We slam ours with air though.
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by tigertooth View Post
    x2 Easily done for under 100 bucks.
    Senior Member Jetdream'n's Avatar
    Sep 2009
    Concord, NC
    Lets see some more pix. Everyone.
    [QUOTE=tigertooth;4012666]??? Aint sure I follow that theory. Gonna require a timer to turn that pump off!!![/QUOTE[
    The timer is for sure, but that's just so you don't have to hit a button to lift the diverter. The timer turns the diverter into a self automated system usually controlled by a micro switch on the pedal or carb. The reason for the stop is because hydraulics are nearly impossible or 100 percent impossible to control within a 1/2 a degree or less. A stop of some sort is a precision way of controlling the exact amount of up nozzle. Which is very critical.
    This one is on Rat Bastard, part of Those Guys Racing. 10 second World Champion Boat.
    Senior Member bp298's Avatar
    LHC
    here's mine. been using this same stop for 15 years. through 11 championships, including 5 "world" championships, and 2 boats...
    cost less than $20.00 to make...
