need help with selecting a loader grate
Results 1 to 14 of 18
    Oct 2015
    Default need help with selecting a loader grate
    looking for loader grates suggestions . the boat is a mach 1- v bottom , boat runs 78 mph with a grate that was a inch lower then the bottom of the keel. and was only held on by two bolts. moved up and down in the intake in the back
    engine
    forged 557ci
    iron super cobra jet heads
    and a 1050
    618 hp
    pump
    berkley split bowl
    a impeller
    PD droop
    PD diverter
ID:	839705   Click image for larger version.
ID:	839713   Click image for larger version.
    Oct 2015
    Here's the boat
ID:	839441   Click image for larger version.
    Apr 2010
    Rocklin, Calif.
    You can talk to Jack @ MPD, or Chris @ B1...what ever you do drill through the intake and get 4 bolts in that! things could get Bad-Fast!!
    Yep, Yep and Yep!
    Oct 2015
    This in my first boat so , got it with a stock 460 and put my engine in it. For what ever reason, the 2 back hole nearest the transom are already thru bolts but frontshe are not
    Cant really tell but does the loader have reinforcment betwern the two upright parts. Could be a pretty good loader as it sits if so
    Apr 2010
    Rocklin, Calif.
    Quote Originally Posted by tigertooth View Post
    Yes...a good pic of keel would help
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by Johnnygofast557 View Post
    with the engine installed, could you even get to the front of the intake to put nuts on the screws if it were drilled through? not uncommon to see just the rear two holes drilled through for nuts on top, with the front holes original. no matter what loader it is, you need to remove it a couple times a year at least, check for any cracks or deformities, scrub all the rust off of it. having a loader break can turn into a really bad day.
    Senior Member uniboarder's Avatar
    Dec 2012
    If she runs,,,let her run.
    Oct 2015
    Here is another look of it. I took this and the boat to place diverter and he recommended I cut the ramps back and re-install it and see what I get. I will get some more of it installed
ID:	839729   Click image for larger version.
ID:	839737   Click image for larger version.
    Apr 2010
    Rocklin, Calif.
    Yes!!
    May 2014
    Call Chris at b1 racing
    Senior Member bc18's Avatar
    I would run that the way it is. Take a sideways picture of it installed. Looks similar to a mpd loader.
    Oct 2015
    If it is a mpd loader that would make sense the previous owner had the pump redone before I bought the boat.
    On a side note I figured I have been running the boat with just the two front bolts in it and the grate hanging down .
