Too many options, not enough knowledge..
Results 1 to 6 of 6
    Jan 2016
    Default Too many options, not enough knowledge..
    Hi all! I've just bought a 1977 Caribbean Pacemaker 2100 with a mild 460 in it. It has had an energizer kit put into the old golden eagle at some point. I got the boat cheap because the bowl is missing, impeller is destroyed, and the wear ring is, well, worn. I also own a very good Jerk 12jc with an A impeller. Can I use the bowl and impeller on that energized Jacuzzi?
    Quote Originally Posted by Pacemaker View Post
    The Impeller could likley be used but would probably need a different wear ring ,The 12jc bowl would require fairly extensive work Welding and machining as the bowl bolt size and positioning as well as othe differences would preclude any simple install/swap
    Jan 2016
    Okay. Thanks. Bolt spacing is same, but they are only 3/8 bolts on that golden eagle. Not sure if I'll put the energizer together or just swap to berk. Be a good opportunity to put a set back berk and place diverter on the big bugger.
    Jan 2016
    Look like very nearly same hull as the boat Josh did the swap on that I am seeing pics of online.
    Before G/E
    After
    Jan 2016
    That's the one. I keep drooling over the pics. You are a talented bunch. Very nice clean work.
