Panther Pump Lube?
Results 1 to 7 of 7
Panther Pump Lube?
    Old Timer LeE ss13's Avatar
    San Dimas CA
    Default Panther Pump Lube?
    Guys ... what kind of oil or grease are you suppose to use on a Panther Pump? There is a plug on the inside of the boat just above where the shaft goes into the pump. I was told to lube it each time I took it out. Is that right?
    I don't know what I don't know because I forgot !!!
    Quote Originally Posted by Freedom Child View Post
    They all look alike upside down
    Quote Originally Posted by Wannabe View Post
    A grace of the English language that you obtain simply supersedes all reasonable expectations.
    Monroe, WA
    Don't they just run 90w in there? The plug has a 'dipstick' end on it if I remember right...
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    San Dimas CA
    Malcom is correct on the 90 wt and the reservior "volume" is very small , about 3 OZ as I recall (to much oil will cause the brg to o'heat , if it doesn't have the dipstick I have some, if it has a plug or zerk and appears to have been "greased" its only a matter of time before it fails the double Timkin bearing design was to utilize oil Folks do the "grease" thing because of seal failures on these jets Tom
    San Dimas CA
    Thanks ... I bought the forward/reverse and steering cables for you last year and finally got around to putting them in.
    Quote Originally Posted by LeE ss13 View Post
    You are very Welcome ! Thanks you , Now get busy Springs around the corner !
    Cas
    Cas is offline
    Angry American Cas's Avatar
    don't forget about greasing the rear bushing. The zerk is found by looking into the nozzle....you may need a flashlight.
