Wear ring question
Results 1 to 14 of 17
Wear ring question
    May 2013
    Default Wear ring question
    Im sure this is a stupid question(s). But i wanted to run it by you guys.
    Currently, i have an "undersize" Ultimate wear ring in my boat. Its .010 undersize. When i measured my old impeller it came out to 7.220 and Duane recommended a .010 undersize and never run it on the trailer.
    Now i have a brand new impeller from American Turbine. It is "standard" size. Should i change to a "standard" size wear ring? Or will the .010 be fine just a little tighter? I'm only asking because the boats not here, and i cant measure the clearances until i go up to needles.
    If i need to change to a standard, that is fine but if the one i have can be used since its pretty much new and in great shape that would be preferred. I mainly use the boat at the river so it should be fairly clean water.
    Thank you
    Diamond Bar, Big River
    interesting querry. I'm Curious too.
    May 2013
    Few more questions
    Stick with the "ultimate wear ring"? My Pros are its easy to install, just need to shim the front for clearance. Con is i have to drop the driveline everytime i want to run it on the trailer
    Or
    go with a Conventional wear ring?
    conventional? Shouldered? The cost ends up being close to the same no matter which way i go. Is there really a point in going shouldered? Or will the normal old wear ring be fine?
    Or just stick with a UWR?
    To many options.
    If it matters, the plan is to pull the pump at the end of this year and have it blueprinted/professionally built by B1
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Stick with uwr and get a jetaway if you want to run it on the trailer. Check and see what Duane recommends on using the .010 under one you have.
    Sent from my SM-G900R4 using Tapatalk
    I would check with Duane at hi tech for his opinion as he is the maker of the wear ring as see what tolerance/clearance it will withstand. the stock measurement on the impeller should be 7.225 with a stock clearance of .025 to .035. my call would be to either replace the wear ring to a standard or cut the new impeller .010 on the skirt to be at the same clearance.
    Quote Originally Posted by steves86ta View Post
    Thank you
    The thickness in or inner ID measurment of your installed "undersize" Ultimate wear ring over standard (7.250) should be measure approx 7.240 versus a new impeller which should be 7.225 that combination should net you total impeller to wear ring clearance of approx .015 or (.0075 radial ) versus standard clearance of .025 (.0125) , at any point in the radial clearance) in perfect conditions , this is also assuming you have "0" runout or wear in the pump shaft shaft or impeller skirt, or worn bearings , bushings etc
    Shell Knob, MO
    If the wear ring has just a little wear on it already, I'd go ahead and use it. If it looks perfectly brand new, I'd either go with a standard W/R or true the impeller .005"-.010".
    May 2013
    I ended up ordering a std stainless wear ring. I figure ill put it in, then when it comes time for an undersize one ill already have one.
    Senior Member namba860's Avatar
    Las Vegas, Nevada
    Good choice
    Default curious
    curious as to what had you chose to go s.s. instead of another uwr? avail., price., quality?
    I would have run it. I consistantly put .010 under wear rings on new builds. Only when the shafts bent or impellor is loose on the shaft that its a problem.
    May 2013
    Quote Originally Posted by jetjunky View Post
    Couple of reasons.
    I dont want to pull the transom plates i made, or the suction housing. I dont know if i could get to that side of the impeller to measure front clearance with a UWR with a new impeller.
    And it was 99.99 from cpperformance.
    Lastly. I know its not recommended, but i can run it on the trailer with the stainless wear ring. The UWR no way
    May 2013
    Quote Originally Posted by tigertooth View Post
    Thank you for the input, ill hold onto it incase i need it in the future
    Frozen Tundra, WI
    Couple of reasons.
    Running on the trailer is a nono with any type wear ring
