Anyone Running An HPH From Plave Diverter?
Results 1 to 7 of 7
    Senior Member W.O.T's Avatar
    Campo Ca
    Default Anyone Running An HPH From Plave Diverter?
    Just Curious If Anyone Has Tried One And How They Compare To A Regular Droop or Straight Snoot?
    I know some of the race boats are using them w/ low profile intakes. From what I've seen they work well. I'll be running one on the Place Craft.
    Shell Knob, MO
    They work well. However we have found, that on the boats where they work well, the Snoot works even better.
    High Performance Marine ARS Marine's Avatar
    Feb 2009
    Morris,Illinois
    W.O.T. I take it you're looking to run something on your Daytona?
    If so, I'd stay with a standard droop snoot. From our experience's unless you're running around 850-900 H.P. and your boat doesn't require the extra lift,then you could play with a HPH nozzle housing.
    Shell Knob, MO
    I agree, I'm just used to working with a lot of HP and that was what I was thinking. Guess what I should have said is the high powered race boats that work well with a HPH work better with a Snoot.
    San Diego, CA
    Quote Originally Posted by W.O.T View Post
    I'm running one on my deal and I am very pleased. I also have several friends running them with very good results.
    Campo Ca
    Thanks for the info guys!
