Oil leaking from hose
Results 1 to 14 of 17
    B-Town Bomber CAMDIDDY's Avatar
    Brawley, CA
    Default Oil leaking from hose
    I bought a new battery for my project boat, hasnt ran in over 2 years.
    Started right up. Throttle response was good and everything seemed to
    be working fine.
    However I noticed a small hose at the back of the block (bbc), with a screw and
    a washer on it that was dripping oil all over the shaft. It only spits out oil
    when the engine is runnning, and as it falls onto the spinning shaft it splatters everywhere.
    What is it? is it a drain of some sort? or is it supposed to be sealed? not much of a mechanic so any help is appreciated.
    the hose held by my middle finger...
    Senior Member OUTLAW HALLETT's Avatar
    SHASTA LAKE CA.
    it looks like it comes from the back of the block, where a oil pressure line would go, and someone just stuffed a bolt in it , for some reason. you should be able to follow it back and plug it the correct way,
    Newton Ks.
    Thee should not be a hose attached to ANY port that I am aware of on the back of the block, and a rubber hose on an oil gallery port is just asking for a leak @ 50 to 60 psi.
    Track it down, remove whatever nipple is there, and replace with an apropriate brass pipe plug.
    Oil press. sender is USUALLY screwed in on the lower left side just above the filter mount, although any gallery port WOULD do.
    H.L. Mencken
    Morgan Hill
    Looks to me like a Redneck oil change kit, remove that chit!, just asking for a Valdes redo...
    GT
    GT
    Brawley, CA
    I couldnt really tell where it went, somewhere under the block. May be connected to the oil filter?
    Ill follow it tommorow when I can get some sunlight.
    So sounds like everyone is saying find the outlet and just cap it off right?
    Quote Originally Posted by CAMDIDDY View Post
    It may be the oil drain hose and the previous owner used a pump to change the oil. If ti goes to the pan that would be my guess. It may have gone to a oil primer bottle too although I have never actually seen one.
    Lexington, KY
    Is the battery on top of the pump??? How do you grease the jet pump thrust bearing???
    HJ
    ....like warm apple pie RaceFace's Avatar
    Mission Viejo
    GT
    X2.....get that outta there. No reason for it. Cap it off.
    Race
    Default Pan drain?
    Quote Originally Posted by RaceFace View Post
    Find out what it is before you make the decision to remove it. It may very well be an oil drain of some sort. Even a small hose will drain the pan over time. Park the boat, open the drain and come back tomorrow it'll be empty. Usually the hose is long enough to stick thru a transom hole into a bucket or pan....ID it....Ray
    LOUD BOATS SAVE LIVES
    Morgan Hill
    LOL, right now he don't have to, it gets sprayed with plenty of 10W-50
    GT
    GT
    Anaheim Hills
    Im guessing he would have to remove it for that twice a year task.
    Brawley, CA
    ok the hose runs down to a "T" at the bottom of the block,
    which has either a filter or some kind of pump on one end (has an
    electric wire on the end). It must be a drain or something to
    change the oil. I removed the hose and capped it off. theres
    another outlet with a valve incase i ever need to drain it.
    Shell Knob, MO
    You did the right thing. That thing with the wire running to it is the oil pressure sender for your oil pressure gauge.
    Lexington, KY
    How could you drain the oil from there?? That's above the level of the oil in the pan and even above the oil in the filter. I've replaced my oil pressure sender with all the oil in the engine, didn't leak a drop. My guess is that it was so they could hook a mechanical gauge up to it if they needed to, like if the electrical gauge was giving them a funky reading and they needed to verify.
    HJ
