E85. Who using it? Likes? Dislikes?
Results 1 to 14 of 18
    Jul 2009
    Default E85. Who using it? Likes? Dislikes?
    Pretty much what the title says. Looking for some real world experiences, Thanks in advance.
    A little more information would be helpful.
    Is it blown, how will you use the boat (performance or cruising), is this a new motor, rebuild or using the motor you have now?
    I use it in a blown flat and like it. I also have a slightly larger performance V-drive and would not use it for that boat.
    I'd do the e85 again in the flat though.
    Calculate the fuel you expect to use now and reduce the running time and or distance by 1/3. Does that work for how you use the boat?
    You could put in larger tanks as an option, but that cancels any performance gains you would get from the e85.
    Oct 2011
    Sandia,Tx. 78383
    I just switched from AvGas to E85 ...8/71 with Dominators , motor is just now being dialed in but so far this stuff looks to be the ticket 👍🏼
    http://oathkeepers.org
    May 2014
    Not a huge deal on the west coast but you need to get a test kit and check the e85
    Can you prove it cabron? TSR2626's Avatar
    Jul 2012
    Northern IL/Mohave County AZ
    I've run E85 in my flat on an N/A 540 EFI engine and have been happy with it. It doesn't take long before my twin 9gal tanks are empty though. It was pretty easy to get a decent tune with the stuff too. seems to be a little harder to find when I go out to our place in AZ. I assume there are places to get it in havasu?
    Oct 2011
    Sandia,Tx. 78383
    Another main selling point for me was 105+ Octane fuel for about $1.60 a gallon compared to over $5 a gallon for AvGas and $7 on up for race fuel ? ....is a no Brainer swap
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Quote Originally Posted by TSR2626 View Post
    No E85 in Havasu
    Quote Originally Posted by Gopher711 View Post
    Where are you paying 5 a gal for avgas? Havent seen it that high in a couple yrs its under 3 a gal here. I was gna put methanol to the next tt ls im building but now that avgas took a huge dive im gna run it again.
    Jul 2009
    Performance and cruising. New build. Prices are the big draw to using it.
    Where are you at with your compression? Cam soecs?
    Ada, Michigan
    It doesn't take long before my twin 9 gal tanks are empty though.
    I've gone 36 miles and used 16 gallons just cruising at 35 mph +-
    I didn't think that was too bad.
    On the dyno at 29# boost it looked like it used close to a gallon in 10 seconds.
    Quote Originally Posted by Psycotic Break View Post
    My experience with e85 is, you probably don't save money using e85. While it does cost less initially, it also requires more fuel used for the same cruising distance.
    You will not be able to find e85 at most marinas, if any. The ethanol absorbs water from the air and creates problems for long term use near water.
    E85 does provide a fairly high octane for the money though, and makes a great inexpensive performance fuel.
    If you are building an engine specifically with e85 in mind, it may be possible to get the fuel economy up to nearly match that of gasoline.
    Most automobiles from the factory capable of using e85 are designed to run on pump gas (e10) and up to e85. To do that, there must be compromises made by the factory.
    If the engine is somewhat made specifically for e85, those compromises don't have to be there, and it can be made more efficient.
    I'd guess that most of us who use e85 are more interested in the performance portion, and accept that were not going very far when we start with 10 gallons of e85 and like to play.
    Thanks UNCHAINED, you confirmed what I assumed was about correct.
    I had thought near the 2 mpg wouldn't miss it far for cruising, and with a 10 gallon tank about 4-5 runs is all that I am comfortable with, and it's time to look for more fuel.
    My guess is your turbo's are more efficient than my 14-71 and you also make more power, by quite a bit.
    Jul 2009
    Well I haul my own fuel so that's not really an issue. I fill a tank now so I guess I'd just be filling two. Lol
    I think at 13 to 1 e85 is quite a bit cheaper than gas. I guess the real question is all things being equal well as they can be. What kind of power difference do you get at 13 to 1 with e85 over 10 to1 and super?
    Jul 2012
    13.5cr 268/268 750/770
