Pump loads one time... not the next?
Results 1 to 14 of 39
    Default Pump loads one time... not the next?
    18 ft baja, 454, berkely pump. The pump randomly wont load from an idle, when it does it runs great, the next time from idle it just spins. any ideas? Pump was supposedly just rebuilt before I got the boat.
    i got skiillllzzzz.... fast76rogers's Avatar
    clearlake ca
    you need a air bleed at the top of your bowl.bleeds out air so bowl stays emty of air.im sure somebody will pop up a pic of one
    Glendale Arizona
    Prima jet. Not so sure that's his problem though. If the boat has been in the water and run already, then it does this........it doesn't seem likely that it would/could have air trapped in the bowl.
    If it does it only after getting it off the trailer and running it for the first time, then that's pretty normal and this lil dude should help.
    No Longer Recovering 454Rocket's Avatar
    Torrance, CA - Havasu, AZ
    Open the hand-hole cover and take out the crap in there...
    Senior Member Futs's Avatar
    Orange CA, Big River
    Quote Originally Posted by 454Rocket View Post
    Just don't do it while your in the water unless you want to sink....
    plastic grocery bag stuck on the intake grate.
    BTDT
    #55
    Spiral out MikeF's Avatar
    Just back it into the water w/ the reverse gate open every time......wait till it loads....then go. No big deal and no reason to throw $$$ at it.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    sucking air through the mechanical seal maybe? if the rope seal was replaced
    broken keyway? although there would be other issues related to this one.
    I had a crimped hand hole cover o-ring that was letting air into the pump that caused a pretty poor hole shot. The motor would spin up pretty high and then drop down but it did it all the time.
    Thanks for all the ideas!!! It happens randomly on the lake. No crap in the hand hole, no restrictions on the intake grate,
    Shell Knob, MO
    Are you standing real hard on it when this happens, or just trying to take off normal?
    I havent dared stand on it hard because of this issue, it happens off idle. anybody know where I can pickup that prima jet dohicky? do I have to pull the bowl to drill and tap for it?
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    sucking air through the rope seal maybe?
    I have a pretty good leak when the boat is running, tightening the rope seal down a lil (Like a quarter turn) stopped it, would this help in cavitation also...pulling air through the rope seal?
    does anyone have a pic of the prima jet installed they can post?
    Cas
    Cas is offline
    Quote Originally Posted by R1P S4W View Post
