How fast is your Jetboat?
Results 1 to 14 of 36
    Chantilly Va.
    Default How fast is your Jetboat?
    Lets talk engine size and design,ie ...CID,
    Comp ratio,impeller. Fuel...
    Hull design.Just curious where
    I stand.I will start now,81 Sunkisst Gullwing,87 octane,AA aluminum,461,.030 over 454 Chevy.2 bolt ,flat tops,Edelbrock oval port heads.Guessing about 8.5:1.to 9.5:1..Crower .630 lift solid roller.107deg. lobe seperation. Dart intake ,850 Holley DP.Ran top speed last Sat.87.3 mph GPS...edit...2 degree up wedge,rideplate,stuffer&shoe...
    Senior Member Futs's Avatar
    Orange CA, Big River
    Quote Originally Posted by sunkisst View Post
    What RPM?
    18ft bahner bubble deck ,468 w/mickey charger ,bush wacker diverter.and a bimini top 85 mph.
    The car on the road next to the lake was going 80 and i past him
    79 SWTD 548 chevrolet afr heads custom cam duel domis pump gas mpd prepped pump runs over a hundie at 6200 rpm
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    86 TX20 youngblood 562. Lots of cool shit, svo block J&E, Crower, cobra jet heads, dominator pump, rpm varies and my good friend nos.... well over a hundie
    "Don't make me get my penguin"
    Quote Originally Posted by UNASHAMED View Post
    A Ford guy.... they let Ford guy's in here ?
    S CP
    Big Inch Ford Lover
    i got skiillllzzzz.... fast76rogers's Avatar
    clearlake ca
    1976 rogers bonneville tr 19,weight heavy,489 bbc ,805 hp,berkley b imp. ,droot,funky ride plate,last run was 92.7.will have new set up done in two weeks.hope i will run over 100mph.
    Well mine ain't doin' shit at the moment (blew the motor...workin' on a new one). But when she WAS running...
    18' Marlin Tigershark (close to a Tahiti Tiger copy)
    Chevy 454, 9.5:1 comp, estimated 500hp
    With a loader, an Aggressor droop w/2* down wedge, and an American Turbine AB cut impeller she ran 79mph GPS @ 5400 RPM with no shoe or ride plate.
    San Diego, CA
    19 daytona, 740 hp, best of 9.24 in the quarter. 114mph. 395lb hull
    How much Nos ?
    S CP
    How much Nos ?
    S CP
    none, all motor!!
    none, all motor!!
    Very efficient boat
    Oh yeah mine: Not as fast or quick as Bosticks G/W
    And 3mph short of the goal:
    And it only takes 450+/- more hp to run 5 mph slower than widowmaker
    Sleeper CP
    Big Inch Ford Lover
    No way! That cant be right!!!!!! How can you run over a hundie with a hole in the piston Jusss playin, did you find out what the problem was?
    G H E T T O F O E L I F E
    My turn....
    1980 sunkisst gullwing 525lb lake layup(heavy bottom and potatoe chip sides and deck) Filled with grape soda and slices of watermelons
    MOTOR
    454 mag motor(stock)8.5-1comp,stock rec port heads,stock rockers,stock hyd roller,Steel crank,Forged pistons,Msd ign,Dry Bassetts, with a weiand 177 blower(450hp est.),single Holley 800dp
    PUMP
    berkeley pump set @ 4.5* ,2* tapered shoe 0.125 in the hole, custom loader
    17-4 shaft,jetaway,double drilled suction/bowl, worked bowl,dominator fully detailed "B",D.P.S Inducer,Detailed AT Droop, Place Diverter,
    Not GPS'd yet. Running somewhere in the 80's
    Going to a stock BBC 330hp motor so it will be safer
