Intake question
Results 1 to 9 of 9
Intake question
    Feb 2015
    Default Intake question
    In this pic the back corners were cut off on the Miersch intake now I heard a few reasons why but makes no sense any thought would help.Thanks
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
    May 2014
    Looks just like mine I don't understand your question ??
    Feb 2015
    The back 4 bolt holes are actually cut off and the intake shortened then 2 holes were re drilled and tapped ? TBScustoms yours are just the corners are cut off.
    Senior Member Double A's Avatar
    Apr 2010
    Yakima, Washington
    Mine came with the corners cut off as well. I see where yours looks shorter as you said. Did you buy it new? I don't see a reason a guy would need that done.
    Feb 2015
    Quote Originally Posted by Double A View Post
    Thats my thought ,Came off my Daytona and put it into my PD and never gave it a second thought until I noticed it was shorter about 2 1/2 inches and I could see just the edge of a bolt hole on the back side suction was drilled to match, looks factory just wondering why someone would cut it back I see no gains.someone on here probably knows or maybe the guy before me got a new saw for Christmas and wanted to try it out.
    When you buy a new lopro from mpd you have to send him your su:tion to have it matched to the opening. I feel like thats what happened to your lopro. Do you still have the same suction housing on it now.
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by tigertooth View Post
    mine was never matched to the suction piece, and it fit perfectly. then after the old suction piece finally gave out (thrust bearing failure 30 years ago, finally cracked half way around the bowl flange), we replaced it with another berk and it fit perfectly. just a plain 'ol berk suction piece...
    Feb 2015
    Yes it even had alignment pins in it ,so it must of had some time spent on it.
    The alignment pins tell you what I said.
