how do you finish your bulkhead
Results 1 to 11 of 11
    Member wsm9808's Avatar
    Feb 2009
    Default how do you finish your bulkhead
    I'm getting well past the halfway point on my Daytona restore, and I need to do something with the bulkhead.
    I'm thinking I would like to do it in black to blend in with the bottom and sides. I thought about bedliner spray, but not too sure about that.
    Maybe cover it with black carbon fiber cloth? Can you put the carbon fiber cloth on with fiberglass resin like you would with fiberlass mat, or does it have its own resin for something like that?
    What has worked for you?
    Ladera Ranch
    I wouldn't use a bedliner. That stuff belongs in a truck bed, not a boat. It can also hide problems like cracks or delamination. Have you considered gel coating/painting and or flow coating it? Couple guys have gone that route and it looks really trick.
    Bullhead city AZ
    I have used the spray on liner before with great results. if you spray it close ( not to close ) its smooth and if you spray it like the stuff says its coarse and is hard to clean . leaves a textured finish and dust/dirt love to get in there...
    Feb 2009
    I used the trunk spatter paint/coating (was used in car trunks) on the boat in my avatar. It looked nice, but I sold the boat about a year later, so I dont know how its holding up long term.
    So Cal
    Here's how TRG (toddnjuzz) did mine for me:
    Senior Member 76 Bonneville's Avatar
    Valley Center Ca
    Gel to match the boat
Name:	Rogers Carpet 008.jpg
ID:	36088   Click image for larger version.
Name:	4-5-08 Rogers 002.jpg
    Santa Clarita
    Bedliner in the boat = HillBilly
    JMO...do it right.
    Feb 2009
    JMO...do it right.
    As I said in the original post "I thought about bedliner spray, but not too sure about that. "
    Thats why I'm asking for help on here so I can do it right.
    Please, what is right?
    Scott
    El Cajon, CA.
    "Right" would depend on what's right for you. I've seen pics of bedliner with color added used for a non-skid coating that looked OK. I personaly wouldn't use it on the bulkhead or transom as the stuff is heavy. I used Rustoleom roll/brush on paint I bought at Home Depot and it turned out OK, it's real durable for paint. You can also sand it down a little bit and apply some resin to it. Probably the next step up would be to do gel coat/flow coat to it. A lot of what's right depends on your wallet, time, and skills.
    If the wood was premo condition i'd say leave it natural..... It looks to be weathered a bit. Sand it smooth and paint it with gel, if it has been coated with resin. It would not be the end of the world to replace the bulkhead, and leave it natural looking. Mine was covered in a layer of mat then covered with cloth. The fibers disapear when rolled out by the fiberglas roller.
    Quote Originally Posted by BUSBY View Post
    That looks killer!! Are those stringers thinner that 2x material?? They look thinner,maybe it's an optical delusion. Sleek yours is coming along nicely also,floors(stringer, bulkheads, ect) look awesome,nice work for sure
