Old School Jet on New School Race Boat 2016
Results 1 to 14 of 17
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default Old School Jet on New School Race Boat 2016
    April 14, 2016
    Hello People
    I had to return to old school technology. New school tech / equipment just didn’t perform as I thought they would. My American Turbine bowl and 3A Stainless impeller were installed in 2015 and cracked, broke / welded before April 14, 2016.
    I want to give thanks to Jim Brock - Cyclone Speed & Marine for the quick turn around of the replacement parts.
    Also notice the bowl is polished all the way through. "Old school part with new school technology"
    The 149 Tsunami BGJ has old school technology reinstalled to help control the part failure.
    Willis
Name:	Berkeley Bowl 4142016.jpg
ID:	875281   Click image for larger version.
Name:	HCM Inducer craked 2015.jpg
ID:	875305   Click image for larger version.
Name:	Polished Bowl 2016.jpg
    149 BGJ 156.74 MPH @ 1000'
    okie, lake Texoma
    Hmmm, have you ran it yet?
    H8-2-W8
    [email protected] first pass
    Gardena, CA
    April 14, 2016
    Hello People
    Hass
    No.
    This is the replacement parts setup and different inducer that I will use at Lake Ming 4-23-16
    Willis
    Oct 2011
    Sandia,Tx. 78383
    what's the deal with the spacer between bowl and droop ?
    http://oathkeepers.org
    Gardena, CA
    Quote Originally Posted by Gopher711 View Post
    April 14, 2016
    Hello People
    The spacer is just there to try and equal the length of the ATJ Bowl that was replaced.
    Trying to keep the “E” ticket ride as similar as possible to the way it rode with the American Turbine stuff. The spacer made the total length long by a ¼ inch.
    All the other setting are the same as they were at the last race, ride plate angle, nozzle angle, tune up.
    Naturally the impeller was changed too, the 3A Stainless was cracked and welded. Don't think its a good idea to use in this boat.
    Willis
    Sacramento area
    Default 3A impeller
    Hey Willis,
    Always enjoy watching you run, always looks good! Im wondering if l can see what your 3A impeller looks like? Can you post a picture of it?
    Good luck on your next outing, be safe.
    schick
    Gardena, CA
    Quote Originally Posted by schick View Post
    Hey Willis,
    schick
    April 14, 2016
    Hello People
    Schick
    The 3A Stainless blade at the bottom is the one that was repaired by MPD, and the race prep work. The size is standard.
    Jack said the run out will be a little distorted, but nothing to write home about. The impeller is for sale.
    This impeller will work fine for boats with less than 1400hp, probably will have to have it cut down to something smaller.
    Willis
Name:	3A SS Impeller.jpg
ID:	875481   Click image for larger version.
Name:	3A SS Impeller (2).jpg
    Oct 2011
    Sandia,Tx. 78383
    I figured the spacer might be a trick to make the hull think the pump was setback farther than it is and change the thrust leverage angle . Same as running a setback plate on an outboard to take advantage of the extra leverage it provides
    Gardena, CA
    April 15, 2016
    Hello People
    No trick,
    but there have been boats with the jet nozzle set way back, Marty Stretch Limo had a deal where the nozzle was way out there.
    I think that 21 foot boat ran the “8’s” at Ming.
    Willis
    Sacramento area
    Quote Originally Posted by willis View Post
    April 14, 2016
    Hello People
    Schick
    Willis
    Rite on Willis, thanks for sharing.
    Be safe, schick
    Senior Member uniboarder's Avatar
    Dec 2012
    Great thread! Thank you!
    Senior Member Double A's Avatar
    Apr 2010
    Yakima, Washington
    How did it run Willis?
    Gardena, CA
    Quote Originally Posted by Double A View Post
    April 27, 2016
    Double A
    We had some uncontrollable events that couldn’t be fixed at the track. Spike Gorr, Gorr Fuel systems, had the parts I purchased to solved the fuel issue, but the others were not solvable at the track.
    I have found the issues and they are being addressed, so with that being said, the 149 Tsunami with the “Old School Jet” will be ready for the May race.
    Ralph and Spike Gorr, thank you for your help
    Gorr Fuel Systems
    969 Commander Dr.
    Lake Havasu City, Az. 86403
    Willis
    Sacramento area
    Hey Willis,
    What bowl, impeller and induced where you running when you went [email protected]? If you dont mind me asking?
    Thanks, be safe. schick
