place diverter
Results 1 to 9 of 9
place diverter
    seattle
    Default place diverter
    i am almost done installing an energizer kit on my jacuzzi YJ. it is now an american turbine. i was talked into a manual place diverter. since i didn't have one before, i am asking for some pictures of how the cable is routed. pictures of the actual through transom. is there a part or piece that mounts around the cable? just sylicone dosent sound right??
    any and all help would be appreciated, thanx
    SR
    SR is offline
    Cajun Member SR's Avatar
    Laf. Louisiana
    These are made to seal cable through transom (cable seal/Rex Marine)
    Quote Originally Posted by 1975sleekcraft View Post
    If you bought the Diverter new It will (should) come with the seal pictured above in the kit Below is a "positive seal" make now available in thru hull/bukhead and also a threaded version as direct replacement for the shifter cables for all popular jets Tom
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    Tom I need two of those fittings if you have them please send me 2
    Thanks Tye
    Cool Tye that means I can reduce my Debt huh
    seattle
    Default thanx
    thanx for all the help! but there is more, if you can?? my boat is a 75 sleekcraft sportster 18'. i need to run the diverter cable?? i have heard that i want as much of a strait shot as possible. i really want to run it behind my side panels, then out with as little cable showing as possible??? i have been told to run it straight back, under the back seat, then down the stringer, then straight out the transom, with as little bending as possible??
    i would like to see some pics of your cable routing, and shifter placement.
    any and all pics will be appreciated, i need to see yours so i can make a good decision on mine.
    any and all advise welcome,thanx
    going out now to take a couple of pics
    seattle
    Default pics
    here are a couple of pics
    what do you think?
ID:	36235   Click image for larger version.
ID:	36236   Click image for larger version.
    SR
    SR is offline
    Laf. Louisiana
    The advice you were given about cable placement was right on.Most peeps mount diverter control right between front seats,closer to drivers seat.Cables crossing the floor take away from the clean look but it's practical. If you realy can't take the cable exposed,you might be able to run the cable under the false floor to the bilge,then out.
    Member Flash's Avatar
    My boat used to have a YJ and several years ago I converted it to a Dominator similiar to what you are doing. Just from my experience make sure you epoxy the inside of the suction housing where it meets the bowl. Without the epoxy, it creates cavitation and burns up impellers.
    Good Luck
