[Question] Olds 403
Results 1 to 2 of 2
Olds 403
    Apr 2016
    Lightbulb Olds 403
    here is what I got
    Is it worth rebuilding the olds 403 motor? and if so where do I find the rebuild kit? Would I be better off putting in something else? and what would interchange with it? Thanks
    Quote Originally Posted by Jason Smith View Post
    here is what I got
    All comes down to your budget and what you can afford ,Consider what it will take will take to make the current engine work to your needs and satisfaction and then weigh it against the cost of a BBC or BBF for example and what a swap might cost given the different peripherals (exaust mounts etc)
