Going to make wideband A/F sensor adapter plate for exhaust - need quick answer
Results 1 to 13 of 13
    Apr 2012
    Default Going to make wideband A/F sensor adapter plate for exhaust - need quick answer
    So I have access to a 3 axis CNC at my work and I am going to have a 1" thick aluminum spacer made so I can plug in my Innovate Motorsports wide-band O2 and get some real A/F readings to help tune my boat. It's a jet boat and runs wet logs, so obviously i have to keep the sensor dry. However my question is, when i unbolted the snail off the manifold, I noticed the gasket has water jacket slots on the snail side, but not on the manifold side. Are they blocked off on the manifold side for a reason? Because if there is no allowed water flow from the snail to the manifold, then why does the snail even need the gasket with the water jacket cutouts? Seems like they should just both run the block off gasket. Does this make sense or am i missing something here? Reason I'm asking is i need to know if I have to machine the water jacket slots in the spacer or of i can just leave it solid. See pics...thanks!
ID:	878049   Click image for larger version.
    "I'd love to help you out wags, but there is larger issue concerning breast cup sizes on another thread that we have to work thru first. This subject suddenly became a non issue." - GN7
    Shell Knob, MO
    it would help to see a picture of your complete engine so we can see how your water and manifolds are hooked up.
    Tower Park Resort, Lodi, CA
    Could do it either way. However, I'd strongly consider machining them on the three sides that wont have the sensor. Just thinking a little more surface area for water to contact wouldn't be a bad thing. Don't think it's mandatory though. Certainly not for any plumbing/water flow concerns. I hope the sensor stays dry there. Let us know how it goes.
    Senior Member kurtis500's Avatar
    Have you run these before in the exhaust? Just an FYI, I ran the Holley MPFI system for 5 years and had nothing but trouble with the O2 sensor getting knocked out by steam/water etc. I went though about 1 sensor per summer. I moved it around even had it mounted at the very front of the manifold closest to the cylinder farthest from the water discharge. This setup is with manifolds and the snail.
    My advice is to carry a spare sensor, when my O2 sensor went down it sent the motor into a overly rich setting and I had to get towed. I eventualy took it off last year and sold the whole system and cant be happier. If you just doing it for O2 readings, Id still bring a spare.
    just my .02 after much anger and frustration
    Apr 2012
    Best two pics of the motor I have. Water tee's off from the jet pump goes into the rear of the manifolds on both sides, then out the top of the manifolds onto the front of the block, then out the thermostat housing (no t-stat) and into the snails, then out the back of the snails into the exhaust pipes.
    The O2 is strictly for reading the AF rage. It will have no effect on the motor and how it runs, just how my tuner will alter the fuel tables depending on what the gauge reads. I know its running mega rich as is but want to know at what RPM's and KPA ranges we can safely lean it out.
Name:	ScreenHunter_59 Apr. 25 09.45.jpg
ID:	879265   Click image for larger version.
Name:	ScreenHunter_60 Apr. 25 09.45.jpg
    Shell Knob, MO
    In answer to your original question; ", then why does the snail even need the gasket with the water jacket cutouts?" In your application, it does not need the cut out.
    As far as to sensor operating efficiency and longevity, I'll leave that to the others.
    Apr 2012
    So basically someone just used that particular gasket but didn't need to. Ok cool thanks makes it an easier machining operation and I can just buy 4 of the non-jacketed gaskets.
    Apr 2012
    Got the adapter plate machined over the weekend. Just need to drill and tap the hole for the sensor.
    Shell Knob, MO
    Looks Good!
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Nice
    QE 439 Twin Turbo
    Apr 2012
    Got the machining finished up and the spacer installed. Also got the gauge mounted in the dash and all the wiring ran and the sensor hooked up but didn't get pics. Going to hit the lake Wednesday and see what AFR readings I'm getting.
ID:	887202   Click image for larger version.
ID:	887210   Click image for larger version.
    Superb. Nice job.
    Keep us posted.
    Apr 2012
    Sensor installed.
