Need a little help
Results 1 to 2 of 2
Need a little help
    Senior Member K-034's Avatar
    Mar 2012
    Default Need a little help
    What is the trick to installing a steering tube bearing for a old school Berkely jetovater without tearing up the $40 transom seal, this is the set up that moves the steering tube with the jetavater, if that makes any since, I will try to get some pics up later
    Any advice would help, thanks in advance
    Quote Originally Posted by K-034 View Post
    The OEM bushing set up for the JOV is a simple piece that allows for the steer tube to move in and out relative to trim adjusment as you may already know, the question is , is this boat equipt with the original set up ? so many have been modified over the years or "rigged" pics will help but basically the piece is a hard plastic part with a out seal and inner oring
