i was running autolite #25 in my castiron heads
Results 1 to 7 of 7
    Jul 2010
    Default i was running autolite #25 in my castiron heads
    now i have afr aluminum heads and they said to run an autolite 3932 not sure if thats a colder plug was curious what you guys think 468 bbc tunnel ram with with 750s 10/1 compression msd 6 running 93 octance timing at 32 degrees
    good starting point , read um and see what they say
    Jul 2010
    ok thanx i allways liked ngk better but not sure what they be ?
    Quote Originally Posted by duty View Post
    There are a lot of NGK "equivalents" to choose from Autolite 26 - Alternative spark plugs
    Jul 2011
    Dammit...Albuquerque N.M. for now
    IMO...you might find autolite has a bit bigger selection of ranges. If you can find a "real" parts store w/a paper cataloge...check the buyers guide/heat range chart in the back. Also...don't forget, sometime you can use 5/8" hex plugs in place of 13/16"...space permitting. We did a lot of this in my dirt-track days.
    corona calif
    Default spark plugs
    Correct me if I m wrong an Autolite 25 a short reach hot plug and a 3932 is a long reach racing plug very cold, make sure you are installing the right plugs
    Jul 2010
    thats what the guys at afr said to start off with ...........
