Twin Turbos on jacketed manifolds
Results 1 to 6 of 6
    Oct 2012
    Default Twin Turbos on jacketed manifolds
    Could someone please put up some pics or add a link to turbos mounted on water jacketed marine manifolds, logs or high risers. Had a look at a guys twin turbo marathon race boat with a twin turbo LS1 and the heat created is insane. He had to shift coils and leads, shield spark plugs, bolts stretch things get melted when running boost for extended periods. It seem it would be far easier for me to mount turbos to water cooled manifolds. Thanks
    Join this group on fb
    Oct 2012
    I not on FB, will have to join I guess
    okie, lake Texoma
    Heres some LS ones a guy a has just started offering on FB
    H8-2-W8
    [email protected] first pass
    Oct 2012
    Just purchased a new set of Kodiak high rise manifolds less risers, available here immediately. Any more pics or links of turbo and waste gate arrangement would be good.I have twin 68mm 82AR Borg Warners, twin 50mm turbosmart waste gates, 2 stage water to air intercooler
    Registered Parker Allstar SFV2RVR's Avatar
    SFV/PARKER
