The wiring begins
Results 1 to 14 of 15
The wiring begins
    Feb 2015
    Default The wiring begins
    Looking for the right gauge wire to run for accessories.
    Rule bilge pump 500, Gauge wire ? I'm thinking 16
    Fuel pump 16 Gauge ?
    Starter ? Tilton mini .
    Alternator ? I have the 1 wire mini style .
    Buying wire in bulk so I dont have to do this twice and dont want over kill or not enough,Thanks
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    No sizes but good info.
    Blk -Grounds-General
    Blk/Brn -Pump Grounds
    Blk/Red -Voltmeter Grounds
    Blk/Org -Isolated Accessory Grounds
    Blk/Yel -ignition stop
    Blk/Grn -Water Level Sender Ground
    Blk/Blu -Lighting Grounds
    Blk/Gry -Nav Light Grounds
    Blk/Wht -Battery Parallel Solenoid
    Brown -Pumps-General, Bilge or Sump (Manually Switched)(Also alternator starter to Ign.)
    Brn/Red -Pumps, Bilge or Sump
    Brn/Org -Power feed to Auto Bilge Switches-Pumps, Fuel/Oil Tranfer or Priming
    Brn/Yel -Baitwell or Aerator
    Brn/Grn -Fresh Water Pump/Water Maker
    Brn/Blu -Head Pump
    Brn/Vio -Washdown Pump
    Brn/Wht -trim pos sender
    Red - Battery Feeds Unprotected
    Red/Vio -Misc. Accy. Main Feed Protected (fused) from batt to trim panel.
    Pink -Fuel Sender
    Org/Blk -Audio System Feed
    Org/Brn -Electric Head-Sanitation System
    Org/Red -Wiper Port
    Orange -Accessories common feed- Dist Panel to Acc switch-Anode Electrode-Mercathode
    Org/Yel -Diesel Pre-heat
    Org/Grn -Wiper Stbd
    Org/Blu -Communications Equipment
    Org/Vio -Navigation Equipment
    Org/Wht -Wiper Center
    Yel/Blk -Choke - Neutral saftey trans mounted
    Yel/Red -Start Solenoid(starting circut), Neutral Safety
    Yel/Org -Powered Ventilation, Fans
    Yellow -Bilge Blowers -(also alternator DC output)
    Yel/Wht -Rudder Angle Sender
    Grn/Red -Stop Solenoid/Kill Switch
    Grn/Yel -AC Grounding
    Green -Bonding
    Grn/Wht -Engine Trim in and or tilt down
    Grn/Org -Engine Independent Trim down
    Blu/Blk -Cabin Lights
    Blu/Brn -Oil Temp Send
    Blu/Red -Cabin or Cockpit Lights Port
    Blu/Org -Engine Independent Tilt Up
    Blu/Yel -Lighting Circuits to Remote Send
    Blu/Grn -Cabin or Cockpit Lights Stbd
    Blu -Instrument & General Lighting
    Blu/Vio -Courtesy, Boarding Lighting
    Blu/Wht -Engine Trim Outand/or Tilt Up
    Light Blue -Oil Pressure
    Vio/Red -Eng. or Generator B+ from Breaker
    Vio/Yel -I/O Trim Up (ballast bypass)
    Vio/Grn -I/O Trim Down
    Vio -12v Ignition-Generator or Engine
    Vio/Wht -Trim "Trailer" switch
    Gry/Blk -Mast Light
    Gry/Red -Spotlight Remote
    Gry/Org -Docking Lights
    Gry/Grn -Strobe or Beacon
    Gry/Blu -Spreader/Flood Lights
    Gry/Vio -Windlass/Winch
    Gray -Navigation (running) Lights, Tach. Send
    Gry/Wht -Anchor Light
    Wht/Brn -Temp. Alarm or Indicator
    Wht/Red -Fuel Alarm or Indicator -((Ignition module to Dist.)Mercury Thunderbolt Ignition)
    Wht/Org -Fire Alarm or Indicator
    Wht/Yel -Air Flow Alarm or Indicator
    Wht/Grn -Water Press/Flow Alarm or Indicator - ((Ignition module to Dist.)Mercury Thunderbolt Ignition)
    Wht/Blu -Oil Press Alarm or Indicator
    Wht/Vio -Voltage Alarm or Indicator
    White -General Alarm Usage, Yamaha Kill Switch
    Tan - Water Temp sender
    Tan/Blu -Warning system sense wire (Audio warning)
    Pink -Fuel sender
    QE 439 Twin Turbo
    Senior Member Eliminator21vdrive's Avatar
    Jun 2011
    Diamond Springs, California, United States
    Default Wiring
    Feb 2015
    Good info so far .
    Sacramento area
    Default wiring diagram
    I saved this about 5 years ago, knowing that it would come in handy one day. If I remember correctly it was courtesy of Tom at Jetboatperformance, THANKS TOM!
    No wire size, but hope it helps.
    Be safe, schick
    Default Wire Gauge ??s
    Quote Originally Posted by leadslinger View Post
    For what you have listed: Alternator 10 Ga. Fuel pump 14 Ga. Starter (I assume you mean the sol. connection 14 Ga. Bilge pump 14 Ga. instruments 16 Ga.
    For the fuel pump, I would use a relay. Just my opinion, after wiring several street rods and boats. Also I might suggest that you use non-insulated terminals with
    shrink wrap tubing if you want a really clean "look". Slide shrink tubing onto wire (1 inch long) then install terminal and crimp. Next, slide shrink tubing over crimped
    area of terminal and apply heat to shrink tubing. (I use a heat gun) Hope this helps you.
    Dave
    Quote Originally Posted by Maxey View Post
    Dave
    I would agree with the suggested sizes and the use of a relay for the fuel pump.
    The use of MARINE WIRE, such as Ancor is also a very good idea.
    There are several reason to use marine wire with no down sides.
    The MARINE WIRE should be of the tinned type, as it help resist corrosion.
    It is more flexible than automotive SAE wire and even though both may say what gage wire they are, the same gage MARINE WIRE will carry more current.
    Marine wire contains more strands of wire which makes it more flexible and why it carries more current. Marine wire also is made to withstand the marine environment and chemicals used around boats.
    Do not use any wire that is a solid core wire similar to what's used to wire houses. It is not designed to withstand vibration and will crack.
    Color coding is a must to save your sanity while wiring, and in the future if you make a change.
    It does cost some more, but it's a one time item.
    Feb 2015
    Dave
    Do you solder all connections or just crimp ?
    Coast guard say crimp connections only. 14 gage is good for all circuts.. Some circuts will need a relay
    Several street rods that I have done, I crimped & soldered. Because of the vibration involved with boats, I would crimp only.
    Feb 2015
    Good info ,Thanks
    Sacramento area
    Default Label maker
    I bought a label maker that prints on heat shrink tubing. Its a slick unit. Has a lith ion battery and all.
    P-touch EDGE® Datacom Labeling Applications – Brother
    Quote Originally Posted by schick View Post
    Very cool!
    Feb 2015
    So the battery is at the transom and I'm running two leads to the center console POS and NEG and using like a 8 terminal bus/junction block X 2 one for neg and one for pos what gauge wire should that be ( thinking like 10 gauge)also on the bus/junction block I see that there amp ratings on them, which amp should I get,and there on the wiring will be 14 Gauge to switches. junction block will be riveted on the underside of panel the tabs are on for future access to wiring and the oil is Mechanical.
