1st Jet Boat & Pump Options
Results 1 to 9 of 9
    May 2016
    Glendora / Willow Valley AZ
    Default 1st Jet Boat & Pump Options
    I'm looking to by my first jet boat specifically a 23' day cruiser with the below deck seating. My preferred choice would be a Sleekcraft. There are a few boats available in my area right now but they all have Jacuzzi Jet Pumps. Should I wait for one to come up with the more desirable Berkeley pump or would a Jacuzzi get the job done? I'm not too concerned with speed i'm just looking for a reliable cruiser. Also what is the cost for a shop to rebuild a Jacuzzi pump if needed?
    Senior Member namba860's Avatar
    Las Vegas, Nevada
    Most of those were built with Jacuzzi YJ pumps. I have only seen a hand full with Berkleys or Panthers. The YJ is a good pump for that big boat. If you want to upgrade the YJ you can install the Enerjizer kit in it. Most had 455 Olds engines in them, try to steer clear of them find one with a Ford or Chevy in it.
    May 2016
    Thanks for the info. Unfortunately majority of the boats i've seen also have the Olds still in them.
    Diamond Bar, Big River
    I believe Glastron, Nordic, Carribean, Eliminator, Lavey Craft and Cambell also made 23' footers in that era. All good quality builders in the day. May be more options out there for ya then just Sleekcraft. In my opinion the Glastrons were a cool, unique looking hull that performed very well, very efficient design. (good speed/h.p.) The Jacuzzi pumps are built stout with stainless impellers in stock form. Any of these boats will benefit significantly with a diverter installed. Good luck with the search.
    Senior Member uniboarder's Avatar
    Dec 2012
    X2 on the Glastrons. Sleek did offer the Berk 460 pack-jet-option in the late '70s. There out there, just got to find one and plan on a little work if its a barn find. Or worse, back yard find.
    May 2016
    I'm open to all manufactures. I've had a craigslist notification search for a CV23 out for the last 6 months but nothing has come up with a jet drive. Are there any manufactures that I should avoid?
    Dec 2012
    Anything with a roll cage and a water bladder to make bigger wakes!
    Las Vegas, Nevada
    The Sleek Craft was by far the best looking 23 on the water back then!
    sleeks were always a classic good looking hull aptly named. The Nordic, IIn my opinion, was also a very good looking sleek design. Nordics seem significantly more rare. Good luck to the OP. Patience is a virtue, especially when buying a good used boat.
