Thermostat kit
Results 1 to 14 of 16
Thermostat kit
    Apr 2012
    Default Thermostat kit
    Who's running this setup or this exact kit? Any cons to it? anything else you need besides whats in the kit? I was thinking out getting this to help get my temps up for better combustion and less carbon buildup. Right now my average temp when running WOT is 110 and idling is around 130-145. Open cooling system with a gate valve that I always run wide open - worried about hot spots forming in the heads/exhaust so I never close it off. Only disclaimer it says "not recommended for sandy environments" lol.
ID:	887434   Click image for larger version.
    "I'd love to help you out wags, but there is larger issue concerning breast cup sizes on another thread that we have to work thru first. This subject suddenly became a non issue." - GN7
    Apr 2012
    Pic of my motor/hose layout.
    I have that thermostat setup on my Cole, two years now with zero issues. I installed it for the same reason, large Magnaflow water pump just cooling the engine, water temp never made the gauge move, and oil temp was only 170. Now I average 140 water temp and 200 oil temp. I do a lot of boating in the SF bay area delta, which has a small amount of silt with no issues. In an area with a large amount of sand I would think you should be running a sea strainer, regardless of how you are cooling the engine.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Senior Member 78Southwind's Avatar
    I have a used one if you're interested let me know.
    Senior Member BGMAN's Avatar
    Quote Originally Posted by Bonzen View Post
    Not bashing, but I'd consider upgrading that Home Depot water hose to something a little more rugged.
    Apr 2012
    Quote Originally Posted by BGMAN View Post
    Haha I knew someone was going to say something. I have ran it for 3 seasons with no issues. I change it out with new hose every season though. It's rated to 175 degrees and 250 psi but if I end up with a T-stat kit that raises my water temp I will go back to heater hose just for good measure.
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    use that setup on my 460 8yrs now no issues
    I wasn't able to find the spring. I would like $50 plus shipping.
    The Right Coast/SE-PA
    Thumbs up
    I've been running the Rex Marine thermostat bypass system since the mid 90's with absolutely zero issues and I highly recommenced it.
    However, how my system is plumbed I have the one line into the block and two dumps out...water psi never exceeds 11 psi. Never over pressurizing the block, zero fear of damage to head gaskets, good flow through the heads to prevent hot steam pockets and oil temp stays hot enough to burn off any moisture and that's important!
    Senior Member APOLLO's Avatar
    MAHTOMEDI,MN
    Hammer, can you post a pic or drawing on how you plumbed it please? I think I see what you did. Thanks Troy
    Apr 2012
    Thanks for the info guys, I'll probably go with that kit & probably pick up the used one from 78southwind. I'm chasing a really weird fuel pressure drop issue right now at about 3/4 throttle so I want to figure that out before I change any variables.
    Senior Member Bill Oxidean's Avatar
    Not sure if this helps, but this is how mine is plummed up..
ID:	890393   Click image for larger version.
ID:	890401   Click image for larger version.
    Apr 2012
    Great lookin motor
    Senior Member Trigger's Avatar
    Aug 2011
    Lewisville, TX
