Bowl gasket
Results 1 to 3 of 3
Bowl gasket
    Iuka, Mississippi 38852
    Default Bowl gasket
    Replacing bowl gasket. 10 years since it was replaced when the pump was rebuilt and over 200 runs. Getting ready for upcoming KDBA race. Silicone or not? I`ve thought about applying a thin coat of silicone on both sides of the gasket, letting it cure and then install?? Are there any recommended torque values on a Berkeley pump? Many thanks in advance.
    Apr 2010
    Rocklin, Calif.
    For what its worth..thin coat of vasoline both sides, snug-tight, let sit couple hours, re-snug..double-drill unit
    1/2 inch bolt torque should be in the 60 lb. Range. I like to put sealer on non double drilled bowls. They seem to want to blow out between the bolts.
