mph data collection using pressure transducers??
Results 1 to 10 of 10
    Default mph data collection using pressure transducers??
    I seem to remember reading you guys using quikdata were using transducers for mph data collection. Are you guys just comparing gps readings to the voltage output or is there a mph transducer that is already set up volts vs mph ???
    Jan 2012
    St. Louis, MO
    I don't really know the answer to your question. But if you're recording pressure in psig, you can convert that to MPH in a spreadsheet post-run:
    V = [(148.6 * P)^0.5]/1.467
    V = MPH
    P = psig
    This assumes 60 deg F water, which you probably won't be running in. But it'll be close.
    Dec 2010
    Sapulpa ok
    Duane @ High Tech has a chart.
    Thumbs up
    Quote Originally Posted by piston in the wind View Post
    Thanx craig!
    Senior Member bp298's Avatar
    LHC
    we all have the conversion chart's tom.
    May 2014
    Why dosent some one post it !!
    LHC
    Quote Originally Posted by tbscustoms View Post
    because nobody's ever asked? because in reality, not that many people in here would make any use of it? because if someone does buy a data system with a p/e transducer for speed, the person that sells the thing to 'em gives him a chart? because i'd have to go take it out of my binder, scan the thing, save as jpg, save it to the host site, then post from the host to here? that's a lot of time and effort when nobody's asked for it, and I got naps to take, cigars to smoke, etc., etc...
    Senior Member Trigger's Avatar
    Aug 2011
    Lewisville, TX
    Or take a pic with your phone and skip all the bs. Lol
    Sorry Bob, couldn't pass it up. You don't give us many opportunities.
    LHC
    lol, well, if this was facebook that might work. I could take a pic of it with my phone as long as it's not important to be able to read it...
    San Diego, CA
    pretty easy to do with the qwik data 2 or race pack. There is a math function channel that you can set up. That uses the PSI given then enter the equation you want to use to plot on a graph as a channel and it's done. No more calculating, the computer will do it for you.
    Boat 405.
