Help with gm distributor for a 502
Results 1 to 5 of 5
    Junior Member EOSpeed's Avatar
    Arlington , TX
    Default Help with gm distributor for a 502
    The distributor is out of a Kodiak 502 with a carburetor. It was made for EFI. Does it have any advance in it or is it locked. It had a jumper wire in it but no wire that went to a hot wire for setting the timing on a EFI engine. How does it work. Don't wont to run the pump out of the water long.
    Default Distributor ??s
    Quote Originally Posted by EOSpeed View Post
    It has been awhile since I worked on those, but if my memory serves me right, that distributor has "no advance in it". The advance would have been a function of the PCM the
    distributor was originally connected to. If it was me, I would pull it and install an MSD or like distributor with a centrifugal advance. Hope this helps.
    Dave
    Arlington , TX
    Default Dist.
    Thanks Dave
    I pulled this out of a 96 Ultra 15 or so years back. It ran ok. I did just what you said msd, cam, intake and carb. I had it so decided to use it. Had a points dist. in it.
    E.O.
    I believe you can use the pickup coil in those dizzys to signal a msd box, but seems like you had to bypass the ignition module itself. Look thru any old msd instructions you might have, pretty sure you can fire it that way. I ran a 6a on a tbi truck in the 1990's using same dizzy
    Arlington , TX
    Thanks I looked in my old msd book and ther it was. Have a box of msd wires that had all the wires in it to set it up. Wires in the box date back 40 years.
    E.O.
