Steering tube installation
Results 1 to 9 of 9
    Las Vegas, Nv
    Default Steering tube installation
    Soooo, how exactly, is this suppose to be installed?
    Baught it from Marine Industries West, but no installation instructions came with and I can't find any thing online about it.
    actual Install will depend on a multitude of issues , like assembly positioning , angle, hull/transom thickness etc
    Las Vegas, Nv
    Thanks Tom.
    So both plates go on the out side and the bolts thru bolt the transom.
    I am supposin, that I have to drill a big enough hole, to accept the nylon ball?
    Do I need sealant on the nylon ball to tube, threads?
    What is the advantage to this style steer tube vs a regular steer tube?
    Thanks Tom.
    So both plates go on the out side and the bolts thru bolt the transom. They do on mine
    I am supposin, that I have to drill a big enough hole, to accept the nylon ball? likley a relief
    Do I need sealant on the nylon ball to tube, threads? no
    What is the advantage to this style steer tube vs a regular steer tube? no not really we do them both ways
Name:	panther conv 2.jpg
    Las Vegas, Nv
    So, Tom, this type of steer tube doesn't require a set of jamb nuts, one on outer and inner, to keep adjustment or tube from rotating?
    My tube turns pretty easily.
    You refering to the type you purchased? the threaded nylon ball show keep it in "check"
    Las Vegas, Nv
    Yes, the one I purchased. It turns very easily. I can screw it in and out with my fingers, which changes the adjustment of the nozzle, left to right.
    Worried about the friction of the water turning it while under way.
    Theres no rotary action on a steering cable to change things cable so unless the loosness causes a leak concern I wouldnt worry about it
    Anaheim Hills
    Tom, Which style/brand is that?
