Berk R shaft
Results 1 to 6 of 6
Berk R shaft
    Ladera Ranch
    Default Berk R shaft
    I have a berk R shaft that Im considering using. It has some wear from the packing that Id like to have fixed. I was told that it needs to be hard chrome plated. Anyone know how much/how thick the hard chrome can be applied? Who does this type of work and how much does it generally cost?
    Thanks!
    I thought chroming metal weakened it, maybe your talking about a different kind of chrome.
    Ladera Ranch
    According to Jack @ MPD this is the fix for a hardened shaft.
    How bad is the packing surface wear? maybe a pic ? Tom
    also check your PM re the "sleeve" Tom
    Ladera Ranch
    I will post a pic tomorrow.
    Ladera Ranch
    Measured the shaft. Section just ahead of the packing(towards the bearing) measures 1.50. Worn areas are looking to be 1.489 or so.
