Starting all over!
Results 1 to 14 of 35
Starting all over!
    Southwest corner AR
    Default Starting all over!
    Well, here I am at square 1 starting all over! Last run of last season finely got it running it's azz off and droped a valve! And as you all know had to built a new motor. Did an upgrade on motor and pump, changed the impelor going to give a AT HH a try! So it's back to the grind stone till I work out the kinks!
    Motor is in and all new plumbimg done,wiring finished with a few added extras! pump is back and ready to install tonight! If all goes well I will be ready to hit the water Sat. or Sun. but the weather is not working with me!
    Build is a 496 Pro Comp heads 10.1 comp Chris Straub cam profile dominator intake and Chuck Nuytton 850 carb. Produced 700 HP,700 Ftq ought to be fun ride! I was not looking for a race rocket but a sleeper creeper! Scott Seastrum built pump and as I said a few extras!
    I hope everyone has a good boating season and good luck with their projects! WT [IMG][/IMG] [IMG][/IMG]
    WT
    WFL Crew!!!
    okie, lake Texoma
    Looks good widetrack, ought to be fun.
    Tri-Cities, TN
    Lookin' good Coby, Let me know how she runs on the water..
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    very nice..
    #55
    Arcadia CA
    looks great. I hope everything turns out well for you this season
    you already got it dyno'd coby?
    SR
    SR is offline
    Cajun Member SR's Avatar
    Laf. Louisiana
    Hope the rain lets up for ya. Bullet looks shweet. I need to finish mine soon. 68 Camaro project got in the dam way.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    looks good good luck this go around
    1 question why the high dollar hh impeller.
    Southwest corner AR
    Yup, and it's a good flat 2 lines! Not a war horse but should fly my azz!
    WT
    WFL Crew!!!
    Southwest corner AR
    Trying something different to see if it helps! Tested Sunday And man does it bite HARD! I set it a little tight and now got to get a little loosey! WT
    Thanks Guys!
    WT
    WFL Crew!!!
    Tri-Cities, TN
    So how was the acceleration with the new engine? Did you get a MPH out of her yet?
    Chris Straub
    Straub Technologies
    Southwest corner AR
    It has got it! And then some. Got to do a little setup work and it will be flying! Sorry for the bad phone pic.[IMG][/IMG] WT
    WT
    WFL Crew!!!
    Southwest corner AR
    Default not to bad!
    Well, I am pulling the pump back apart and changing the impellor from an HH A to a HH B to see if I can get the RPMs up! The HH A is a biting BITCH over the old impellor! The 496 has no problems moving this boat from point a to b in a flash! We will later install a inducer if the cavitation problems persist!
    As I said in starting this thread "Starting All Over" as always, one thing leads to another. THIS BOAT IS GOING TO WORK!!! We will try a few new tricks to see if anything helps or hurts and post it up! Later! WT
    WT
    WFL Crew!!!
    Senior Member Futs's Avatar
    Orange CA, Big River
    Question? Why are you adding an inducer if "she is a biting bitch"? What were you spinning the HH "A" to and what should the expectations of the HH "B" turn in comparison?
    Im non induced and My turd leaves pretty hard as she sits.
