19' CP with pop-off video - Aha
Results 1 to 14 of 35
    on 3 go..... Slow Burn's Avatar
    Aha - SoCal.
    Default 19' CP with pop-off video - Aha
    This is from last weekend @ Aha. It's our 19' CP making some test passes with the new pop-off & motor combo. The valve worked perfect and the boat seemed to respond well to the changes. We've got a few more adjustments, but it's getting close.
    I can't wait for summer.
    Thanks again Ma & Pa Burn, WG, GS Marine & Mike D.
    Glendale Arizona
    Can I ask how much horsepower your motor is making? Sure would like mine to run like that (or even close).
    Done.... So.Bay*310*'s Avatar
    So.Cal
    Badass! Motor sounds wicked. What RPM'S was the motor turning?
    Senior Member W.O.T's Avatar
    Campo Ca
    Looks Nice! Sounds Great!
    Atlanta TX
    What Popoff valve you using ?
    Aha - SoCal.
    Can I ask how much horsepower your motor is making? .
    Thanks guys,
    It's around 1000hp on the motor, while spinning an A impeller 6500. On the bottle it hits right at 7000rpm. We're using the Mersch valve with the electronic switch(GS version). Couldn't be happier with the way the valve makes the boat re-enter the water.
    I'm still learing to drive the boat and will improve the launch with more practice.
    lc2
    lc2 is offline
    Quote Originally Posted by Slow Burn View Post
    We're so proud -Ma & Pa Burn
    Breathing Diesel Shotgun19's Avatar
    Michigan
    Looking good!!
    031 RIVER4FUN's Avatar
    Looks & sounds awesome. I wish I had known you were here & I would have come by. Usually I can hear guys running from my place at Villa Shores, but I didn't hear anything on Sat.
    Senior Member rivertime247's Avatar
    REDONDO BCH SO CAL
    Default testing
    LOOKED EVEN BETTER IN PERSON.....NICE JOB ON THE COMBO GUYS!
    Default Testing
    Scott,
    Will underdog be at the river easter.
    Norco
    boat looks great!!
    Not to hijack, ok I am. How do you reset the pop off? Do you have to shut down the motor? Can it be done at idle? How bout on plane? Do ya just hit the switch?
    Sorry for the highjack
    lc2
    lc2 is offline
    Quote Originally Posted by wg789 View Post
    Scott,
    Senior Member Mike D's Avatar
    Anaheim/Aha
    Scott,
    Quote Originally Posted by lc2 View Post
    Becareful for what you wish for.
