[Question] Jet pump pressure gauge?
Results 1 to 13 of 13
    Sep 2016
    Question Jet pump pressure gauge?
    I am new to the forum, Can some one post some links as to how I can measure the pump pressure after the impeller in the pump bowl. What type of gauge and fittings do I need? Also what pressure numbers can I expect to see? I am new to the jet pump world! I tried the search forum but nothing came up. Thanks for all you help. Tommy Jordan
    Member 5ribsangerhydro's Avatar
    Jul 2013
    south central pa
    http://www.performanceboats.com/jet-...l-pressure.htm
    you may also want to monitor suction housing pressure before the impeller(lengthy subject)
    I have had a jet drive for many years and never had a need for a pressure gauge on my bowl ,and lets just say I am not the fastest boat in my area by far . Or maybe if you are going to race it at some level, then this is where I have seen guys at the boat drags do the suction ports w/ data collection
    there could be many variables to the original questions , hull design , jet drive ,motor hp,intake set-up, nozzle diameter. what is the intended use and what are your goals?.
    Sep 2016
    Quote Originally Posted by 5ribsangerhydro View Post
    Link you posted will not work, Please check and repost. Thanks
    Jul 2013
    south central pa
    Monitoring bowl pressure Started by HomeBlown57, 06-17-2011 04:48 PM
    is the one name of many topics i found when i did a search for (suction housing pressure.}
    kind of weird, that link did not function. bp298 is one of many jet gurus on this board,
    http://www.performanceboats.com/jet-...-pressure.html
    Sep 2016
    Question How to measure pump thrust?
    can anyone help me with this topic on how measure pump pressure? Or how to tell when I make changes to the pump that the mods I have made increased the pump thrust or reduced the pump thrust. Thanks guys
    I'd guess if you wanted to go that route you could tap your droop snout at 12 O'clock with a 1/8th inch -4 or -6 nipple. Then you'd need a liquid filled gauge that reads up to 400 psi ?? Not sure how much psi a pump puts out on the exhaust end.
    Much is to be gained on the intake side, not sure on the exit side
    someone correct me if I'm wrong, but it's not the exit pressure that moves the boat, correct ?
    Sep 2016
    Exclamation help
    come on guys I need to know how to make my pump/boat pump more effecent/ faster? Thanks
    Pictures of boat .....
    search " duct "
    Sep 2016
    tried search function and the word "duct" did not produce any info! Please provide a link, Thanks
    Jul 2013
    south central pa
    Default read this topic
    http://www.performanceboats.com/jet-...omparison.html
    read this topic above starting with post #44 then re-read it from the start.
    prepare to do your homework,
    tell us what you have and what your goal is?
    Sep 2009
    Walled Lake, Michigan
    Default link
    I am not a jet boat guy. But I have been following this thread for some time. See post 289 here. He references bowl pressure and you can probably ask questions from there. If the link doesn't work, it is the "Anyone know the History of this Placecraft" thread.
    http://www.performanceboats.com/forum.php#/topics/247385?_k=3kkedp
    Margaret Thatcher once said The trouble with socialism is that eventually you run out of other people's money.
    Quote Originally Posted by 2fast4u1 View Post
    Post pictures of your boat.
    If you want to know if the work you've done on your pump has made it more efficient then get a good GPS and measure the speed at different RPMs and compare the performance. It's a far better indicator than is how much psi in in the bowl or exit nozzle
    click on link:
    http://www.performanceboats.com/jet-...9905-duct.html
    http://www.performanceboats.com/jet-...-happened.html
    Now post up a couple pictures of your boat
