If it isnt one thing
Results 1 to 13 of 13
    460 is offline
    ATTA BOY 460's Avatar
    Default If it isnt one thing
    Its another. Took the boat out and oil pressure started acting way funny. Well when it was all said and done after tearing into the filter to check for the worst this is what i found. Seems sum silicone made its way to the pick up. Dont know where its from i can only think its from the oil pan gasket that was trashed. Oil pressure never droped below 30 while driving but at idle it was at like 10 and thats not what im use to So i guess i take the next few weeks and do sum cleaning and trailor matience. Geeeeeees
    Bottom end looks clean as a whistle from what i can see. Gunna look it over real well to make sure there isnt anymore pieces of silicome floating around.
    San Francisco Bay Area
    Cool
    Quote Originally Posted by Fo Sitty View Post
    1) Thoroughly clean pickup tube.
    2) Fully disassemble oil pump and make sure that there is no sealer in the gerotor mecahnism and--equally as important--not in the bypass piston bore which could hold the bypass port open and cause lower oil pressure.
    3) Change oil filter
    4) Use spealer sparingly when building an engine.
    Your noted oil pressure readings are not alarming and I'll bet that your engine is fine. Woudln't hurt to inspect bearings while you are in there....but you are probably just fine.
    LO
    High Flow Dynamics
    lol, right..... Devilman's Avatar
    South Texas
    Funny like a clown? Like its there to amuse you? lol
    Good that you caught it early, should be back on the water pretty quick. 10lbs. huh, you sayin I should worry then too?
    Try not to use so much silicone when you go back together with it ok.
    460 is offline
    Quote Originally Posted by Devilman View Post
    Funny was the look on my face when i saw the pressure dropping.
    460 is offline
    Quote Originally Posted by LakesOnly View Post
    LO
    All of the above were on my list.
    Senior Member NO BUTT NO PUTT's Avatar
    Santee, CA
    Dont Use Sillycone!!!!
    Use Right Stuff!!!
    460 is offline
    Quote Originally Posted by NO BUTT NO PUTT View Post
    Use Right Stuff!!!
    Thats what that is.
    I never use black rtv, guess after 3 years the right stuff broke down.
    No Ty, the right stuff turned Left
    G H E T T O F O E L I F E
    Santee, CA
    Thats what that is.
    That cant be. I have a buddy that builds motors and he uses it on all his builds. He said its never done that. Some he built 7-9 years ago.
    And on the bottle it says oil, ATF, brake fluid and fuel will not break it down. You sure you didnt have some sillycone on your intake or oil pan gasket?
    Senior Member cave's Avatar
    Mesa, AZ
    WOW is all I can say. Good thing you caught that Ty.
    Takin it home
    460
    460 is offline
    It was a long drive home. I prepaired for the worst but hoped for the best.
    Its all good, will clean things up, check a bearing and be back on the water in a few weeks.
    Default application
    When installing silicone wait ten minutes before installation. Silicone must skin over. Pat
    Newton Ks.
    Your bearings should be fine. Once my oil is hot, I run 23 psi at idle.
    Yea, get all that sealer out and don't use too much going back together. A little goes a looooooooong ways.
    Good luck Fo.
    H.L. Mencken
