HEI distributors
Results 1 to 9 of 9
HEI distributors
    Senior Member gregb's Avatar
    Redondo
    Default HEI distributors
    Any of you running one of these in open engine application (Chevy of course) have any problems from the distributor getting wet since it's so close to the back of the boat? Or do they take gettin soaked just fine? Was thinking of changing out my current setup (even though it works fine) to one to clean up the wiring, thanks,
    Greg
    Colfax, Ca
    Never had any problem. If that much gets over the back, it would seem that more serious things were happening.
    Senior Member katchenup's Avatar
    vacaville ca.
    Didn't care for the HEI that I ran, The modulator kept going out. Went with msd 6-AL box, with rev limiter, nice set up.
    Senior Member TahitiRat's Avatar
    Fort Worth Texas
    No problmes here, never saw one get wet but I'm sure it happens. Bet it cant be common
    Avondale,AZ.
    Look for offroad/4wd. sites, there are different colored boots that go over the cap and the wires exit from the bottom of the boot.. I think that jegs or summit had them too.. TIMINATOR
    Southwest corner AR
    I've had real good luck with HEI's Simple wiring and clean. A little bulky! They are limited in the all out running 6000+ rpm unless you add some performance parts but work good otherwise! WT
    WT
    WFL Crew!!!
    Bullhead city AZ
    I just did the same thing your thinking.. I got rid of all that crap hangin of my engine.. I ended up getting the Mallory "race" HEI dizzy. no vacuum advance. I have not ran it yet, waiting on new wires
    And my wiring is alot cleaner
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    A little off thread...
    Never had any problems with mine. It is covered. Runs 5200 all day.
Name:	'08 boat pictures 008.jpg
ID:	37728   Click image for larger version.
Name:	'08 boat pictures 021.jpg
ID:	37729   Click image for larger version.
Name:	'08 boat pictures 022.jpg
ID:	37731   Click image for larger version.
Name:	'08 boat pictures 026.jpg
    Loose, the Dogs of War!
    Redondo
    Thanks for the replies, I've got one coming now, it'll be good to have just a couple wires that go to only the distributor, and not a coil and ballast and such. And I just finished timing and tuning the current setup........
