Ftn ?
Results 1 to 14 of 23
Ftn ?
    21' Liberator Jet NORDIC454's Avatar
    BIG D
    Default Ftn ?
    Is it possible to machine a non FT nozle to accept the inserts? If so, what bore and how deep? I don't have any inserts on me for refrence. Thanks in advance.
    Senior Member NO BUTT NO PUTT's Avatar
    Santee, CA
    Quote Originally Posted by NORDIC454 View Post
    Ask Widowmaker, hes done it before.
    Senior Member SLACKER's Avatar
    Glen Allen, VA
    I was told you could on the newer diverters, but the old ones didnt have enough meat around them to accept the sleave properly...?? I was thinking about doin the same thing but I found a FTN version for a decent price. Sorry I couldnt help, But I can pull a insert out when I get home for ya...
    Tim at Place Diverter told me he can do it, but like Slacker said
    only on the later ones, I can't remember how to determine that
    #55
    newer design is the 1 with the rideplate built in, the old school thin 1's were the reverse bucket diggin sob's
    BIG D
    Thanks for the replies, Its a newer one. Slacker, if you could pull the dims. for me it would be greatly appriciated.
    Colfax, Ca
    I have a newer diverter. Sent it to Place to be machined. The price was very reasonable as I recall.
    the length of the sleeve is 1.28 the od of the sleeve is 3.4835 i personally cut the hole depth 1.25 and stay close to the place measurement for a good tight fit. put a set screw in to wedge the sleeve in.
    BIG D
    Quote Originally Posted by johnray069 View Post
    Thanks, this is the info I needed.
    see if you can't get the aggressor or amt type ftn's, they're longer and do a better job imo
    Senior Member bp298's Avatar
    LHC
    and... there should be approximately a .075 step for the insert to butt up to. so, the "upstream" end of the nozzle (toward the pump) should be bored to at least 3.33 or so.
    Quote Originally Posted by IMPATIENT 1
    see if you can't get the aggressor or amt type ftn's, they're longer and do a better job imo.
    but.. the nozzle should be machined to fit standard ftn's. it won't care if the inserts are longer - most all mine are 1.5", although i've run some 1.75, 2". it's nicer if they all interchange.
    i wasn't sure if place and amt were interchangeable, good to know
    San Diego, CA
    Make sure you spend the time to indicate it in properly before you cut it. It took me some time to get it just right otherwise the step will be larger on one side then the other.
    Boat 405.
    LHC
    don't know if amt/place are interchangeable or not, as i don't know if i've ever seen an "amt" insert. some older nozzles were bored out to a larger diameter for one reason or another. but if they're standardized to a dimension, easier to borrow something different to try..
