scoop question
Results 1 to 14 of 22
scoop question
    Default scoop question
    do you guys have any problems with these turning on you?
    are you running a flame arrestor and is that enough to keep it straight?
    Oceanside, CA
    Mine doesn't turn and I run the spark arrestor.
    Senior Member KLINGER's Avatar
    redlands/ aha quin
    I had a problem with mine turning i just tightened the filter nut tighter and problem went away
    just cut a small slot on the base of the scoop, drill a small hole in the carb cleaner flange and put in a small sheet metal screw so that when the scoop is put on, the slot in the scoop slides around the bolt, and the bolt won't let the scoop turn. i've done it to several of my bud's boats.
    Yucaipa, California
    Yeah, but how much will that screw weigh?
    1992 Eliminator Daytona 21'
    Yucaipa, California
    Quote Originally Posted by KLINGER View Post
    Yeah, but yours turned when the Tahiti blew by you SON!
    I might have a run for the money now that you're not N/A anymore...polish them turbos yet?
    Quote Originally Posted by Tahiti Boss21 View Post
    just take a piss before gettin in the boat to offset the weight
    The Man cordog009's Avatar
    East Texas
    I had one that used to turn. I drilled a small hole on each side of the base and ran a bolt down through the holes to keep it from turning either direction.
    1984 Youngblood TX-19 SOLD
    Senior Member Beautiful Noise's Avatar
    Torrance,Ca/Trailer down by the River
    Another good reason to carry Duct Tape
    I might not be Fast BUT I sure am Slow
    Steve
    Drill a small hole in the Carb air horn (near the base and drive a small hardware store roll pin in the hole, then grind a cooresponding slot in your scoop and or flame arrestor etc Tom
    lots of good info/ideas here thanks guys
    Yucaipa Ca
    Try bungie cords....LOL
    Morgan Hill
    I used two machine screws and nuts through the bottom of my stainless steel Dooley, one on either side of the float adjusment screw on my Holley carb., I like the other ideas better though...(especially the bungie LOL)
    GT
    GT
    El Cajon, CA.
    I cut a very small slit in the scoop in a strategic place where it goes on the carb, I bent the scoop slightly where I had cut the slit so that it would only go onto the carb in one spot. No screws and it never moved. If you look at a Holley it shouldn't be too difficult to figure out. Sorry I don't have any pics of it and that boat is gone.
